1991 c1500 rear axle to 1987 r10
Mmmiguel
phoenix, Az
miguel
R10/C10
I want to see if I can switch 1991 transmission and rear axle on to a 1987 r10 5.7. I’m thinking it could fit but not sure what adjustments to make ?
ali_c20
Austria
Alexander
C20, K5
Welcome from Austria. Post some pics.
Transmission is direct fit if both trucks have the same transmission.
Driveshaft length.
Axle width.
Spring perches.
That's my first guess what to look at.
Strick
Dunn, NC
Harold
C20 Crew
The OBS 88-99 trucks have a wider stance than Squares. The spring & shock perches will need to be relocated.
HS
Redneckgirl79
