What brake lines to get for lifted c10
randomTruckKid
Rockport tx
I can't find any extended brake lines for 79 c10. I need 6" lift ones.
Thanks
CountKrunk
ATL
Count
C20 Custom Deluxe 3+3
v8 350
Might have to make them yourself
Rumbledawg
the back 40
K30 crewcab
have you tried Skyjacker?
i got a set of their 8" lift stainless brake lines on my crewcab, and their DOT
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
Off-road design.
Washington
Worth mentioning, I “think” the split between light and heavy duty brake hoses is 1/2 and 3/4 ton the same. Heavy 3/4 (C6P) and 1 ton the same.
My C6P 3/4 ton is a different design than K10 and light K20s.
I found both types to be plentiful and had no issue getting the right length.
Just measure what you got and add the appropriate length.
Heck Amazon has a full set front and back chinesium ones for $99
But ORD, superlift, skyjacker, 4 wheel parts are a few places pretty certain to have them.
randomTruckKid
Rockport tx
Alot of the websites I looked at Said the lines were for 4wd trucks only.
I have a 2wd
Washington
I have a 2wd
That’s right. You’re building a donk. I forgot.
Umm, yeah probably not a big market for old lifted 2wd. However great chance the fittings are exactly the same 2wd to 4wd.
I’d either order a Scamazon set of 4wd ones with plan to return if not the same or take a trip to the local Vato Zone. Have them pull a c10 brake hose and a k10 hose and compare the fittings. Then you know for sure.
Doppleganger
OH-MI: Just like it sounds
Found them. Here's what I ordered:
https://www.inlinetube.com/products/ct1018
I used the rear line but the fronts were too long. They are braided stainless and measure 25" long. If you have any use for them, shoot me an offer.
randomTruckKid
Rockport tx
If I buy the fittings I need then the hose. I could just cut it to size? Right?
Just add to your existing steel lines and relocate the end to use your stock hoses, 3 couplers 3 steel lines,a little common sense,fab some brackets or zip tie them.done!
randomTruckKid
Rockport tx
Just add to your existing steel lines and use your stock hoses, 3 couplers 3 steel lines,fab some brackets or zip tie them.done!
Don't quite understand? I just need to extend the rubber part.
Extend the steel lines that the rubber lines screw to,then use existing rubber lines. I took a pic for you the steel line is behind the rubber line unscrew the rubber line add an appropriate length of steel line, bolt a bracket to the frame to hold the longer steel lines and hook your hoses back up.
90_burb
