Fuel Pump Sending Unit Main Harness
Doppleganger
OH-MI: Just like it sounds
Does anyone know where the main harness (from the selector valve on the right side) enters the cab? I have pics before disassembly - there is a main harness going forward on the right side and another that crosses over the crossmember to the left side.
I think part of that crossover harness is for the left tank, but there is a main harness on the left side that is from the tail lamps as well - just cant tell if the plug/harness at the solenoid valve goes forward and into the cab on the left or right side of the frame.
Its a mess enough figuring what wires and fuel lines go where with EFI.
Thx.
Old Guy Bill
KY
Bill
On my 78 there are two separate harnesses. The tank wiring is a round plug that goes up the drivers side frame rail and enters the cab below the accelerator cable.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
Pretty sure this is how mine was
IIRC the grommet for that harness actually is a female-female 4 prong plug.
CalSgt
CA
Casey
Here’s a picture from when I took mine apart, I think it went over the PS frame and back through a grommet in the frame to the switch (not totally sure that was correct though)
Doppleganger
Here's one of the pics I have of when I pulled the motor and some of the wiring was exposed. The PO must have gotten a great sale on solid core red wire and fudged it everywhere by cutting out chunks of the original harnesses.....so not sure if what I'm looking for was gone when I got it. I know the Pollack valve didn't work - was stuck on one tank.
CalSgt
CA
Casey
I’d gamble the Pink wire coming from the DS frame is the sending unit wire for the gas gauge, I believe it goes to the bulkhead
aaron06
