Heater not working but blower motor working just fine.
Christie
Dawson Creek, BC Canada
Christie
C 10
So my heat/defrost is not blowing in any air but my actual blower fan seems to be working just fine. However I was told that my wire keeps melting by the previous owner (hopefully this makes sense to someone). If you know what I’m trying to describe please help. It’s currently -23 degrees Celsius here. Having heat would be awesome right now.
RanchWelder
Earth
Blazer
355ci
1) Make certain your ground wire to your battery is not covered with acid and corroded.
2) Look for a ground strap from your engine block heads, to your fire wall.
If you have one, move on. If you do not have one, either add one or run a wire from your negative battery terminal to a new screw on the fire wall, for now. Use a self tapper, and a washer and scrape the paint off wherever you add one. Try not to screw into anything important?
Find a blank spot on the passenger's side not inside the heater box, if possible.
If you have a ground to the fire wall...
3) Could be this.
Heater Resistor module is failing:
Make certain the connector is not burned up or melted.
If you have an ohm meter, you can check the coils across the terminals and verify they all have different resistance values.
You can see where each coil connects through the housing to a terminal.
Each wire is different length so each blower setting changes the fan speed.
4) If you need a new connector, see the link below and find the correct one.
5) If the coils are melted, broken or touching, then try to bend them away from each other or buy a new unit before you move forward.
If you have a dead rodent in there, now's the time to get it out.
If it looks good and not burned up, you just saved yourself buying the resistor unit!
6) Or this dash switch:
Same same, make certain the connector is not broken or melted.
These fail or short circuit. If yours is original, replace it so every other test works correctly.
7) This might be under the hood:
Make certain it's not melted or the wiring to the firewall has not been damaged, cracked, hacked up or broken.
If it is, you'll need the wiring connector as well. It's a relay and handles high voltage. Buy one and be certain it's good.
(See the link below and search electrical connectors).
Check here for the parts:
https://www.rockauto.com/en/catalog....7l+350cid+v8,1030217,heat+&+air+conditioning
Find part numbers from ACDelco or Standard Motor Products, if you can afford them.
Most stuff will work OK from the better brands.
Cheaper stuff might not last too long, but will get you by.
After you replace these things, change the fuses for the heater system and make certain the wires from the blower to the dash controls are not broken, cut and taped or accidentally hitting the metal dash.
You might need to carefully remove the glove box screws and get a flash light behind the radio or open the dash covers to inspect the connectors and the wiring, properly.
If the blower was bad you should be seeing a blown fuse or hear the bearings screaming, the fan making bad noises or smell's; like burning.
If somebody hot wired the fan motor without a fuse directly to the fuse panel, you'll see it when you check the fuse box.
Hot wiring the fan is a no-no.
Radio mods can cause these issues, if there's old wiring hanging around and shorting things out.
Make certain the correct amperage fuses are in the system before you move forward.
Look for blown fuses first.
If the fuses are blown replace the switch parts from above and reinstall new fuses, after you replace the electrical bits above.
Fan resistor could cause the others to go bad in sequence.
The best way to repair the system is to repair everything I showed you, or anything shorting can cause each item to break again.
Your connectors are very old. Stuff breaks down since 1977.
There might be a ground wire missing from behind the dash near the ash tray.
Look for a broken floating black wire and attach it to any screw it will wrap around under the dash.
Lots of times, that ground wire was attached to the push button lighter.
If it's blown or the ground is broken from a 20 year old radio mod, then find the ground, remove the lighter push button full of crud and tape off any loose wires you see with no place to go, so they don't short out on the metal dash.
The lighter circuit can be eliminated and taped off, so it doesn't cause a problem.
If it's full of dirt, then disconnect the lighter and tape it up.
Next spring you fix everything?
Christie
Christie
C 10
RanchWelder,
Thank you so very much. I’ll look into this when the weather gets warmer here in the next couple weeks. I really appreciate your attention to detail and walking me through each scenario.
DrvnDrvr
Central Oregon
Al
Have you removed the fan and checked that a critter hasn't got in and made a nest in the heater chamber?
RanchWelder
Earth
Blazer
355ci
The rodent issue was already mentioned.
If you have a rat, and you turn on the blower, you'll know it, unless you cannot smell anymore.
If you smell a rat, clean the duct work before you get sick.
They can get way inside of the system.
You might have to remove all the duct work and wash it all out with vinegar.
You Got this!
The lower blower speeds go through the resistor pack, and the high speed is a direct connect through a separate fuse. The separate high speed fuse is in a wire that runs across the top of the firewall from the junction next to the brake booster over to the blower relay. My ‘75 GMC kept frying the fuse holder, so I spliced in a new fuse holder with a blade fuse. It’s been fine since then.
To check inside the plenum and pull out debris :
- remove the glove box door. Find screws that go directly up through the flange.
- remove the vertical plastic piece right in the middle of the plenum
- look/reach inside the plenum and clean out the junk. It will,be a treasure trove. Move the heat control back and forth to verify that the blend door cable moves and routes air through the heater core. With the truck running, put your hand next to the heater core to verify it is getting hot.
Assuming you have A/C, also check to see that the vacuum-operated doors move as you switch the controls.
RanchWelder
Earth
Blazer
355ci
It's 2% of what you don't know that kills your heater
Great advice!​
The vacuum system flappers could be blocked, like he suggested^^^.
Deleted my entire old school heater duct system and made my own blower module.
Kept the upper plastic duct and removed everything else.
Deleted my A/C condenser and blocked off the firewall openings completely.
Rewired everything 12 gauge with extra fuses, everywhere.
It's not hard to rebuild these older systems. It just takes commitment.
Lil' aluminum, lil' skills at bending some metal and drilling a few rivets, crimping a few fuse holders correctly; you can rewire and make it very good.
Used my old heater core.
My heat is amazing, without the resistor module at high heat, high blower, all the time.
Used a rubber tire tube, cut to length with super zip ties, to match my new fabricated aluminum bent metal heater blower unit to duct my plastic upper dash duct work.
Installed a 3/4" ball valve in the heater supply hose from the engine block, so I can shut it off from recirculating through the heater core, in the summer time.
It works great in Montana in -35.
Defroster rock's.
Rewiring the entire system with modern wire, adding extra under dash fuses and switches for semi-truck blower controls worked great.
I use a Kenworth push pull switch on my dash, with new fuse holders and properly crimped connectors.
My truck is old. Anything I can improve with off the shelf USA made Semi-tractor trailer parts and switches, (which are made to last decades), is what I use when I get rid of the OEM vacuum and B/S system switches.
YMMV.
Hope this helps.
If you want pictures or wiring diagrams, please email me directly.
I can post here if it does not take over your thread, if you like.
Useenamez
