Don-T
- Jul 28, 2022
- Vermont
- Don
- K10
I have finished my Dana 44 in the front and it works very well. It now has a 4.11 gear to match the rear along with a Powertrax worm gear limited slip.
I did the same with the rear 12 bolt axle back in July. It has a slight whine on deceleration at anything more than 20 MPH. I am thinking about taking the axle back apart to reset the pinoin as I think it is too close to the center of the ring gear. I have added drive and coast pictures below. I am wondering if I can get the gear set to be quiet with a better pattern or would I need to replace the ring and pinion. The axle has about 800 miles on it since the rebuilt. If I can reset the ring and pinion I would only need to buy a new pinoin seal. I plan to resuse the bearings as they were new with the rebuild. I have everthing else.
