Factory 3/4 ton wheel replacement.
TCK1
Idaho
Travis
k25
Hello all,
I’m looking for replacement wheels that will replicate the factory wheels so I can still use the dog dish hubcaps. My originals were 16.5 inch rims and I’m wanting to go to a 16 inch rim just for the ease of tire selection.
Thank you in advance.
Carb'ed Vortec 350
@Grit dog has some wheels on his rig you might like
84GMCSierra
Central Arizona
C2500
Stockton Wheel has them, and if you get 16", and want them restored, they can do that too and they powder coat them factory colors
Big Ray
North Carolina
Ray
bought a set off ebay from a guy that blast and powder coats them. Think I paid around 75 each...I'll find his site for ya
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
As an eBay Associate we earn from qualifying purchases.
My ‘75 GMC had factory 16.5” split rims and swapped them out for stock 16” 8 bolt wheels I pulled from the junkyard. I pulled them all off GM trucks, but in that timeframe I think the Ford wheels will also fit. They charged me $25 each for the tire and wheel, but the tires were old and mismatched.
I had the tire shop install new valve stems and mounted new 245/75r16 load range E tires, since they are a similar height and load rating to the old 16.5” tires.
84GMCSierra
Central Arizona
C2500
I know I'm going to catch hell for this, but will these fit on my 84 C2500? I know they are Ford rims but I like the slotted look. I need to restore my factory 16" steel wheels and was wanting to go with these as a temporary setup. Maybe add some white letter tires if they are available.
squaredeal91
Greg bush
1991 SB
I like those too but no.. they will not fit, those are SD pattern. That's what I have on the front of yellow. Her front axle is from an 04 SD.
Auburn, Washington
Stockton wheel website turned to 100% clickbait bullchit articles about car repairs for dummies. WTH happened?
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
The owner, Frank Mauro Jr, committed suicide in 2011. The business closed but was reopened by new owners sometime later. From what I've read, there's no custom work being done anymore and they don't respond to emails or phone calls. Might as well forget about Stockton Wheel.
I hear good things about Wheelsmith >> https://thewheelsmith.net/
Jleopard77
