Engine Doesn’t Like Starting When Hot
CarterDawson
WA
Carter
K-20
81 K-1500
It’s got a 305 with Edelbrock performer intake, AVS 2 Carb and headers. I bought the truck this way. I wouldn’t waste my money on the 305. Oh well. When I drive the truck enough for it to get hot, and turn it off, it doesn’t like to start. It rolls over real slow, for about 7 seconds. Then speeds up and fires up. Like it’s flooded. But after is cools for 5 mins it fires up immediately. Is the truck overcarbed? Should I put smaller jets and rods in? I can’t figure it out. Just set the float level today. It’s been doing this since I bought the truck. Thanks.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
I'm not big on edelbrock carbs but they do run okay. even the 1406 can be over jetted for a 305 and some 350s. Does it seem like it's vapor locking? I've had similar issues in the past.
CarterDawson
WA
Carter
K-20
My initial thought was vapor lock. But I don’t think that’s the case anymore. After going through the whole fuel system there doesn’t seem to be any vulnerable spots.
waterpirate
delaware
v10
5.7 tbi
My timing was off and the truck acted like yours.
QBuff02
Central IL
Quincy
Edelbrock carb=Vapor locking. Put a phenolic spacer between carb and intake. It's boiling the gas out of the carb when it heat soaks. and check the timing as well.
Rickf
Grafton NH
1974, 1954 & a 1937
If the starter doesn't have a heat shield, then you might try adding one.
scrap--metal
MN
Calvin
'85, '81
K10, K20
All the suggestions above are good, and any one of them could be a possibility. Does your truck have headers?
starter is getting heat soaked.
^ This was happening to my Camaro last summer. Would start great cold, but hot it seemed like the timing was too advanced to start. In reality the old started was too tired to turn over well while hot. Headers without a heat shield get that starter HOT. A new starter solved the issue. No heat shield necessary.
CarterDawson
WA
Carter
K-20
Yes. I added a phenolic spacer. I didn’t notice it helping at all.
Jleopard77
