I can't get my ashtray back in
AaronW
MT
Aaron
V3500
Ok, so this is really dumb, but I can't get my flip-out ashtray housing back in, and I failed to keep track of how I removed it. It's an 89 V3500. I've been trying it from the front of the dash, and I can't see how I could get it in from behind the dash.
From which side does it install? I'm sure there's somethign pretty obvious I'm missing.
Aaron
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
From the front side. The open hole facing out of course. Then it'll just be a tight fit but they do indeed slide right in.
I use the wiggle method as well.
With a BFH it will go in...LOL
Like Mason said, it will go back in with a little patience. IIRC, put the top side in first, and than wiggle and curse a bit, it will go back in.
Royal Sierra 454
Goodyear, AZ.
Scott
15 GMC Royal Sierra
On my 76 K5. My ashtray goes in from the back. Too wide to install it from the front.
Finkaire
Finkaire
California
Loren
Silverado c10
Once figured out, do you use your ashtray?
Royal Sierra 454
Goodyear, AZ.
Scott
15 GMC Royal Sierra
I bought one of those ashtray cup holders. Like it! My ashtray seemed too wide to install from the front. Tell you the truth, I was able to install it from the front, it wasn't pretty. That's why I feel it would have been a lot easier from the back?
C10SLEY
Chapel Hill
Caleb
383 stroker
I kinda have this same issue.
I took mine apart and rebuilt and upgraded, but now I can't get the door to shut when the ashtray is in...
PrairieDrifter
North Dakota
Mason
There are three nubs on the top of the tray. You need to push past the first one that's alone, it helps lock it in there.
Octane
Atlanta
Eddie
Too few smokers left in America now to remember how to remove, empty and reinstall an ashtray? Lol
1975K20
