Key Powered Pink wire with black stripe?
BJedi76
Soldotna, Alaska
B.J.
GMC Sierra Classic 1500 4x4 SWB
305”
What is this wire?
It is key on, powered
it comes from the firewall block and it is pink with a black stripe.
1986 GMC 1500
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Pink with a black stripe is power source with the key in run and start, powered by the ECM fuse. Solenoids and sensors are powered by the ECM, then the ECM controls the ground side of of the solenoid.
Be careful what you try and power on that circuit. You can create other problems.
BJedi76
Soldotna, Alaska
B.J.
305”
Is it useless now?
should I remove it?
I was really hoping that would solve my electric choke not opening when the engine is warm, problem.
it’s a project. Lol...
it is indeed a pink wire with a black stripe thath as key on power. you did well
talltidefan
US
Butch
K5 Silverado
Is it useless now?
should I remove it?
Yes, I do believe that is what you need to hook to choke. I think mine went to old stock Rochester metering valve than to choke and think it changed color. Been a minute since all that has been hooked up.
Sent from my SM-A102U using Tapatalk
Is it useless now?
should I remove it?
your electric choke needs live power to open. if you make it switched ignition(as well as run like olds stated) then your electric choke, if functional and adjustment is right, is going to open. If its warm out, it may not be closed fully. or will open quicker idk. either way, to do factory requires some components you may not have and some wiring to be done.
if you want to "just" make it work, I personally did a tap connection off the power feed to the wipers. easy to find. but i have the old vacuum junky wipers, im not sure what you have. just needs ignition on power. you could use a fuse tap for the wipers and run that way to not draw down the wiper circuit. If you dont wire it to key on, but to always on, you will drain your battery. You could do a switch on its own.. but dont forget it.
squares and most GM did this:
"Most used an oil pressure switch in the power line to the choke. This way, the choke doesn't start to heat up until the engine is running and there is oil pressure. On my 62 F-85, I ran a fused wire (20 A fuse) from the BATT terminal on the alternator to the switch, and from the switch to the choke. Very simple to wire and very clean. I like to use the Standard P/N PS64 switch. The middle terminal works the OIL light, the other two are a normally open switch that closes with oil pressure. Use these to control the choke. If you have an oil pressure gauge instead of a light, simply use a brass tee fitting to connect both this switch and your oil pressure sender."
i borrowed these explanations for these. this one coming is for the g body setup:
"The other way is to use a relay that is triggered by the field wire on the alternator (brown #1 wire on SI-family alternators, for example). The field wire is only hot when the alternator is turning. This is how GM wired the stock G-body cars with electric choke when the gauge package was installed. Of course the down side with that is that the choke will close if you break the alternator belt. "
If youl eave the key on but not run the truck, know youll need to give some gas or it will probably be too lean to start quick if its cool down enough. Like, I like to switch on key and turn on one of my aux lights outside the truck. because i have it controlled on switched ignition, but if i were to try and start it cold, its gonna take a few seconds
satansdad
