Cydways
- Oct 4, 2020
- Council Bluffs, IA
- Mike
- V2500 Suburban
I have a 1990 v2500 suburban with the 14 bolt semi floating rear axle. It clunks into gear in both D and R. Also after it gets warmed up there is a faint grinding/whirring nose coming from the rear. The u joints are good and the oil level is full. If I lay under the truck and turn the driveshaft by hand it will turn a good 60 degrees before the wheels start to turn.
Could this be a bearing issue or is my ring and pinion about completely worn out?
Any help is appreciated, thank you!
