77 4 speed throw-out bearing replacement
Thedivingpirate
Christopher
k2500
Hey there,
I have searched the forums looking for a step by step procedure, ones I have found are so old that the pics dont work anymore. I have a general idea what I need to do, just would be nice to see the procedure prior to my attempt at replacing it. Anyone have a link to a video or how to guide that I can reference to change out my bad throw-out bearing on my 77 k25?
Thanks for your time
Would the shop manual illustrations suffice? I can show you the 1980 shop manual, it's under ch465 overhaul. The procedure should be the same if not very very similar. Is it mated to a small block? Not sure if that would change procedure because of clearances or anything
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
Have no videos or anything, but for a 4 wd, seems easier to me to take the engine out. That being said, I've never had a transmission jack or anything either.
1975K20
