- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
I don't think you read my post correctly, I know all about the manual valve body stuff, I was wondering about adding the kickdown feature. My truck doesn't have the kickdown harness, is there a place I can get one new one and the switch?
Ohhhh OK. There are some places that have it aftermarket. I think your current gas pedal bracket will support the switch, and there isn't much to the harness. If your pedal doesn't support the switch, then just get a Th400 pedal bracket from a PAP. Pretty much, 1 wire from the switch to the spade on the outside of the case. You could probably make your own, with a 5ft - 6ft length of wire and 2 spades that can be solderless connectors since it's not a vital critical component.
