Well that sucks
Blackbird
Southern Utah
Cliff
350 V8
Took the kids out for a quick spin in the 83’ C10 because they love riding in it. Let it idle at the house when we got back because it was running a little rough. Wasn’t idled more then 30 seconds and Freon started pouring out of the vents like smoke. Turned the truck off immediately but it still slowly poured out like this for 10 minutes. Popped the hood and the A/c box in the back left was hissing and making a “bubbling” sound. Does this pretty guarantee a full A/C rebuild will be required?
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
That's a first!! For me anyways lol.
I would imagine it's just the evaporator. In the firewall box. If you get it taken care of quickly you should just be able to replace the evaporator.
I'm also not an a/c expert.
ali_c20
Austria
Alexander
C20, K5
Blackbird
Southern Utah
Cliff
350 V8
I’m not sure what system it uses. It’s a 1983 Silverado. What’s the easiest way to tell?
CheemsK1500
K1500
It would originally use R12. If it was properly retrofitted for 134a, it should have R134a sized ports on it or adapters on top of the R12 ports. Outside of that, there’s no way to tell unless one of the components has been explicitly marked as 134a (some replacement compressors will come like this.). Regardless, you’ve clearly lost refrigerant, so you’re going to have to use 134a or pay insane amounts for R12.
Scruffy49
Law Enforcement Navy
Rosemark TN
Jeff
C10 swb
4.3L
Saw that in one of the Reddit groups yesterday. Impressive vapor display. Evap or line popped, update to modern replacements, R134 it, call it good.
I have 4 cans of R12, but not the correct working hose/gauge set anymore. R12 works better, but not worth the headaches.
It definitely looks like you blew a hole in the evaporator (evaporator looks a lot like a heater core). Relatively easy to replace the evaporator, but as was mentioned, once you open it up there are other parts to check and update.
- if it’s already R134a, you can probably just replace parts, pull vacuum to remove the moisture, and then recharge. A/C shops usually use an automated machine to vacuum and recharge, but you can DIY with a vacuum pump and inexpensive gauge set.
- always replace dryer/accumulator and orifice, and use new green o-rings on all fittings. They may have also switched the orifice from GM white to Ford Blue (blue is supposed to work better with R134a), or even added a variable orifice (mixed reviews of how well they work).
- compressor and condenser should still be fine
- hoses may be fine, but should be updated to new barrier hose if they are original and not in good shape
I’m sure I’ll think of more items, and there are other things that may have failed. For example, many converted systems add a high pressure cutout switch, since R134a pressures are higher than R12. Your original system only had a low pressure cutout, which protected the compressor. Excessive pressure may be why the evaporator failed.
Blackbird
Southern Utah
Cliff
350 V8
Does revving the engine have any factor in the pressure in the AC system? I will admit I revved the engine a bit while idling since it seemed to be idling weird/low and I wanted to see if it would help at all. Nothing crazy. Like revving it up to 2,500-3,000 rpms probably
Blackbird
Southern Utah
Cliff
350 V8
Also. Here’s some pics of the AC unit. I noticed the side of the silver cylinder under the hood mentions R12/R134A so maybe the system is already updated?
82SquareBurb
Soddy Daisy TN
Derek
Should just need a new evaporator / accumulator and orifice valve. One thing that will make high side pressure spike too high is if the fan is not cooling the condenser, so make sure your fan is good to avoid any such spikes.
CheemsK1500
K1500
The compressor is only capable of generating so much. Your RPMs will not really play a part unless someone put way too much refrigerant in the system at one point. It is an easy mistake to make when switching from r12 to r134a. r134a requires less refrigerant since it operates at higher pressure. The most likely culprit in your case though, is that your evaporator is old and corroded, and thus the refringent was finally able to bust through the rotten sections of it. After and you swap the evaporator core, make sure you also install a new drier and orfice tube too. Pull a vacuum on the system and verify it holds pressure, before putting more refrigerant in. The last thing you want to do is go through all that trouble just to end up with a leak afterward.
Blackbird
Southern Utah
Cliff
350 V8
So interesting take someone on Reddit has. They say it’s not Freon coming through the vents. They say my heater core is leaking and what I was seeing and smelling was engine coolant vapor coming through the vents.
That would explain the yellow liquid that dripped on the carpet from under the dash, and dripped on the ground below the passenger side door.
YakkoWarner
Central Texas
Wolf
R2500 Suburban
You would never see the refrigerant as a liquid - its only liquid under the high pressures generated by the compressor and immedialy flashes off to vapor when moved to a lower pressure environment (which is how the system works - gas starts as a liquid, then flashes off in the evaporator-absorbing heat in the process, then goes thru the compressor and turned back into liquid-releasing heat at the condensor). If you are actually finding liquid dripping out, a blown heater core starts to make sense.
Original
