4" lift for 1977 k10
dumgothidiot
los angeles
eli
Hey Yall, im working on building a 1977 k10, mostly street driven with light off road use.not building a rock crawler or anything crazy offroad just a very comfortable street set up mostly.. a mall crawler i believe most would call it. it has a built 5.3 ls swap with a 4l80 transmission, NP205, 2800-3000 circle D stall, on 35" tires, 4.10 dana 44 and chevy 12 bolt rear. i am looking to do a 4" lift, it currently has one its on blocks and very original looking steering components. the truck has been off the road since 2002, and im looking to fully redo the suspension and steering system. i would like to keep my budget at around 3-4k im not above going higher although i would like to try my best to stay within that range.
what i'm looking for is some sort of pieced together set up that provides me with the best possible set up for my budget. i am here differing to yalls expertise. let me know what works for you guys thank you all.
Moderator
I do believe you should give Offroad Design a call. You should be able to get the ride you desire for within your budget and it will be better than an off the shelf kit.
Does your rig already have a raised steering arm? Or is the drag link at a pretty steep angle?
dumgothidiot
los angeles
eli
hey bucket i am in the middle of contact with them, they have sent me 2 quotes so far, the first one i requested just the best possible ride quality with my desired lift, it came out to around 6000$ shipped. i guess i just wasnt expecting it to come out to that much. i requested a more budget friendly option without compromising ride quality to hell and they sent me back another quote for around 4000$ shipped which is far more realistic for my purposes. i am waiting to hop on the phone with Tanner over at ORD who has been beyond helpful and patient with working with my lack of overall knowledge of 4wd suspension. i will attach pictures of what i have on my phone as far as pictures of the existing set up. i will also attach the more budget friendly quote and the other more expensive quote if it might be helpful for someone in the future or for consideration if anyone has any other sort of advice or anything to add
dumgothidiot
los angeles
eli
the "budget friendly" quote
dumgothidiot
los angeles
eli
the "best possible ride quality" quote
Moderator
Yeah, so that's not at all comparable to a lift kit. That's all the components you would get with a kit, plus every other part of the suspension and steering. And it's all upgraded too.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Get rid of the crossover steering, and applicable parts and that will cut your cost in half if not more.
Especially since you're street driving it, don't need crossover steering. I would splurge on the leaf springs and upgrades surrounding them. Shackle hangers, bushings, shocks, maybe spring hangers.
I daily a stock steering, 4 inch suspension lift on 35's and wheel a little bit. If i upgraded anything steering it would just be heavier tie rod setup and steering box.
Moderator
I agree about the crossover steering. On a truck used mostly on the road, you'll never notice a difference. Some people will say otherwise, but that's my experience with it.
Now with that said, if you were going to be fully rebuilding the steering system and using a high end steering box anyway, then crossover steering is one of those "might as well" type things.
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
How much lift is currently on it, I would assume it has at least 4" already to be on 35's?
You say blocks, does it only have lift blocks in the rear?
IMHO, so long as nothing is broken, there are not lift blocks on the front or any other known issues, I would just run it with the existing lift. There's nothing wrong with 4" blocks on the rear for a "mall crawler," and cross over steering isn't really needed at 4" either. I'm on the same set of 3.5" re-arched factory springs and lift blocks I installed in 1997 and still with factory geometry steering.
Spend your money on ball joints, tie rod ends, drag link ends, drop pitman arm, ORD Steering box brace, wheel bearings, axle U-Joints, new bushings (bonded rubber will ride nicer than the popular poly stuff), a pretty set of shocks, brakes, Etc.
If money is burning a hole in your pocket I hear the ORD springs are nice but I have no personal experience with them. I believe they can build springs with a spring rate to match the driving type.
Fastduramax
Uranus
K10 Silverado
I'm doing the entire ORD treatment to my 86 7" rear 6" front, If you opt for crossover you have to purchase a steering box anyway I highly recommend the Detroit Speed quick ratio... I'm currently running a 4" Skyjacker Softride, all springs with an added bottom leaf, the straight one, from the OEM pack to give me the rake I wanted and not effect ride quality. The ride quality is awesome IMO and short money for a great off the shelf kit, I think this is my 6th kit ! I do NOT run blocks in any truck ever....
Blazerbiker
Rifle CO
Stephen
K5, actually a Jimmy since it's a GMC
504in
As HMFIC at ORD, thanks for the recommendation and feedback on our help. Tanner is relatively new here and is great. He's a square guy for a long time with a K5 and a crew himself.
Couple notes:
1: with decent HP levels (and it's hard to NOT make good HP with any GEN3/4 swap) spring wrap will likely be a problem so rear blocks become more of a liability. In fact, it's often a good idea to run a traction bar setup with any leaf spring and it's typically more necessary with our custom stuff.
2: with our custom springs, crossover steering is probably more noticible since the bump and roll steer in the factory stetup gets worse when the suspension moves more. That said, even with custom springs, you can definitely drive the truck with corrected stock steering and it can be a large price add so it's a good place to cut cost now even if you plan on it in the future. No matter what, crossover will give you a tighter turning radius with how dramatic the change is
3: Shocks are another place you can drop some cost if you need to. Gas monotubes are nice and durable but about double cost of a typical white body and the real gains in ride quality are in the spring, not as much in the shock. So if good ride is your priority, get the custom springs but drop crossover and put some whitebodies on it.
4: The ride difference between our custom springs and a typical lift kit spring is not minor. When we let people ride or drive in our trucks they're usually shocked it can be that good. Especially on lighter trucks.
5: there's a broad range of personal preference in all of this. Some guys may not put much value on a softer ride. Some guys may tolerate steering quirks/problems better than others. Ask a question about running without a swaybar and you'll see a lot of opinions on that as an example.
Moderator
Couple notes:
Yeah, the sway bar thing, it may as well be a discussion about Chevy/Ford or Holley/Edelbrock, lol.
Supporting Member Army
I have stock 5-leaf 1997 K2500 Suburban springs with a 2" shackle flip on the rear and Tuff Country 4" EZ-Ride HD springs on the front. I also got the ORD sway bar disconnect kit at the same time I put that on. The sway bar disconnect kit made a big difference just getting rid of the sway bar binding from the lift. The springs are stiff enough on it that I usually keep the sway bar disconnected when normally driving it unloaded and I will hook it back up when towing or hauling a few thousand pounds in the bed. I'm probably going to switch to 63" 1/2 ton rear springs in the back and add a traction bar setup while fabbing my own air bag setup.
Everything @Blazerbiker said is spot on. I've gotten almost all my suspension stuff either used locally or new from ORD. The springs were acquired used locally, but all new ORD greasable kevlar bushings, HD shackles, and white body shocks. I thought about crossover steering, but I just don't do enough hard offroading for it to make sense financially.
The bottom line is that the ORD springs will be your best ride. Next best would be the skyjacker soft ride setup. ORD bushings, shackle flip, and HD brackets should be used for either setup.
mo4154
