New Square Jimmy owner, starts with the floors
K5square
Maine
KAD
350ci
Hi,
Joined up to educate myself on Square Blazers.
Picked up a 88' K5 for my son and I to work on. Frame is real nice, body/tub is very bad in the floors.
Was surprised to see NO 1-pc Full Floor Front Sections available for sale aftermarket.
Got to looking at the single new floor pans patch panels included and how the factory designed the floors. I am decided to Fab floors out of steel diamond plate.
The goal for this truck is to be a tough working truck, trail rig, for months there is no salt down.
I am not going to replace floor w "thin" weak sheet metal of factory design. I seen a nice pic of a guy who did diamond plate it looks good.
Seeing how my cab/body is essentially "floor-less" I need to rebuild B-Pillar and tie "hoop" back together.
Once I have the *** B-Pillar rebuilt, I can figure out what to use for the floor support/cross brace *****. The factory part is quite rusty and definitely bent from body sag.
These guys that off-road these hard must use an alternative part in this location???
Could you guys please send me in the direction I need to go to research HD floor pan and B-Pillar Hoop work.
Then I could get the B pillar mounts hooked up and some front brakes plumbed. Steering shaft connected. Rolling stopping project. I really want to get to that point ASAP.
A loose and sagged out body on the frame is no fun!
WFO
Texas Panhandle
ali_c20
Austria
Alexander
C20, K5
Welcome from Austria. Lots of work ahead
Search for K5 diamond plate floor pan, some results pop up.
legopnuematic
Licensed Junk Dealer
MO
Spencer
Welcome from Missouri.
animal
Moderator
Lee
c10 silverado
350ish
:welcome:
Steelbuddha
Firefighter
Central North Carolina
Jonathan
K20 (dump bed)
Another howdy from North Carolina!
Reminds me of the first project car I ever got (1977). 1965 Ford Falcon. There were pieces of plywood in the floorpans, where there was no metal. Replaced everything with diamond plate (very crudely). Learned a lot that summer. Bought the car for $45, sold it for $300. It was when I learned that restoring vehicles makes no economic sense. Didn't make me stop doing it, though. :p
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
Welcome from VA.
86 SCOTTSDALE
Supporting Member Air Force
Oakham MA
Armand
Welcome from MA. Good luck. Had a similar situation on my 83 K5 but she's solid as a rock now.
peats
Pennsylvania
john
k5 c10 k10 SSR doodlebug
406 360 6.2 5.3 171
You're going to spend a lot of money and brainpower on something that needs to be up to original GM specs only. IMHO.
K5square
Maine
KAD
350ci
I'd like to see more of this build
Is he a member?
ali_c20
Austria
Alexander
C20, K5
Jawzjeep
Honk if parts fall off
Washington
Joshua
Suburban
Sounds like lots of fun. My K5 was similar and that the floor was so rusted out the seats were falling in and it had no rockers. Lots of creativity and CAD work to make new panels.
Using an 84 standard cab for the rockers and panels made things a little more difficult because the floors aren't the same but that's where the CAD work came in a you can see. Used a little Mig and it worked fine ish
hauto85
