GTManley
- Mar 25, 2021
- Texas
- Gt
- V1500 suburban
- 5.7 tbi
Hey folks GT here with a delima that has me going crazy.
Truck (1988 1500 4wd suburban, stock tbi 350) runs hot after driving and now has started to idle rough as all get out when under load but returns to a good idle if put in neutral or park.
Here is the back story and what ive done so far.
I noticed one day about a week ago that after a 15 minute drive home i reach the operating temp (usually around 210) but after heading back out to drop my kid off at practice the temp climbs to right under 260, not a fast spike like low water but a steady climb over another 15-20 minutes or so, i reach my destination before it boils over. first thought was cooling system but its all been replaced over the last year ( radiator, water pump, fan clutch, upper and lower hoses, heater core, radiator cap, thermostat twice - first to a 195 stat and then back to a 180 stat and not water level stays where it needs and not losing) and if i let it sit idle in park but still running the temp drops back to normal after about 10 minutes. Next move was to pull a plug and noticed its running extremely lean according to what the plug looked like so here is where i really dove into it.
first off i checked timing and it was spot on (newish cap, rotor, module and coil within the last 2 years), then decided maybe a clogged or weak fuel system so i replaced the fuel filter and no change, then i dropped the tank and replaced the pump assembly still no change. this whole time the truck has operated smooth not jerky or rough idle and no stutter on takeoff. Last night i changed the EGR and checked all the vacuum lines, replaced the line from the solenoid to the egr because it snapped during assembly. i did drop a can of sea foam in the tank then went for a test drive, was able to drive a little more time before the temp started to climb but now at idle in gear it struggles to stay running still drives good just not at a stop. i assume its running rough right now because of the seafoam but i still cant figure out why im still running hot after driving and im running out of where to look for a solution. right now im about 2-3 months out from a new engine replace, just trying to get by without putting all my new parts on a worn out block but still need to maintain a daily driver status till the swap happens.
thank you in advance for any insights or solutions
GT
GT
