A/C stops blowing when I come to a stop??
RaysnCayne
Richmond
R10 Custom Deluxe
Hi all,
I had this problem last summer, and after some solid input, a new blower motor seemed to have fixed it back then. https://www.gmsquarebody.com/threads/a-c-only-works-when-driving.43446/
But I'm running into the exact same problem all over again this summer: the cold air (any air) just completely stops coming through the dash vents when I come to a stop (no matter what fan setting I'm on). The A/C compressor/clutch is still doing its thing, just zero cold air coming out the vents inside. I just checked this weekend and it seems like the "new" blower motor is not working - which makes me think there's something else wrong - something causing blower motors to fail prematurely. Would anyone here have any ideas what might cause this?
I guess if replacing a blower motor every June is what it takes to keep my A/C going, that's a sorta small price to pay vs. replacing bigger parts or getting freon topped off. But it seems quite odd a new (hardly-used) blower motor would take a dump that quick.
SquareRoot
Sounds more like a vacuum issue. First step would be opening the hood (while stopped of course) and see if the blower motor is actually working.
Edelbrock
Earth
Grumba
K5 Blazer
To clarify, your saying that the HVAC blower works when you are driving down the road, but then stop working when you come to a stop? Then starts working again when you start driving?
Or are you saying that the A/C stops blowing cold air when at a stop. And the the air from the HVAC gets cold again when you start driving?
Or both?
legopnuematic
Licensed Junk Dealer
MO
Spencer
If the blower motor stops/is intermittent, first thing I’d check is the heavy power wire going to the blower motor. The molded connector on the end can get misshapen/shrinks or something where it visually appears to be connected, but it’s actually not seated completely.
My 76 is that way, on occasion it’ll fall off or lose connection. Really need to replace the connector.
Easy enough to check, while running, set the blower on high and wiggle the wire. Should be easy enough to hear if it cuts in and out.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Assuming air flow stops, is what you mean, sounds like a vacuum issue. I'm guessing 80's truck? There should be a vacuum canister and a check valve on the drivers side under the wiper motor.
Make sure the check valve is working and the tank isn't leaking.
WFO
Texas Panhandle
And not hooked up to ported vacuum.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
That's a great point too! Need manifold vacuum.
He didn't 100% say it was working otherwise, but. Yes ported vacuum would cause this issue.
HobbyRetainer
