- Dec 7, 2010
- Southeast PA
- Paw Paw
- Chevrolet Tahoe LT
- 5.3, 4WD
Well ****. Went out and disconnected the other line, and NO, i'm on the right line. If pushes some fuel out while in the cranking mode, but not much and none at all in just the ON position. I was sure hoping it would work.
Speaking of fuel lines. I guess I should try to try and save all the fuel line I can from the Burb for the K10 huh? Cuz it needs to be high pressure line. I'll have to replace all the fuel line on the K10 to be TBI compatible.
Yup. Gonna have to find a way to shorten the lines too but at least too much is a good thing.
Your gonna have to run a jumper wire to the relay then and run it right off the battery, I think that is what I did the more I think about it.
