Wideband- a short story
Tobe's84Jimmy
Seattle
Tobe
Jimmy Sierra Classic
i’m heading out to go to work this morning, truck starts, back down the driveway to warm it up on the street, truck coughs and dies(!). the truck restarts but dies shortly after. did my MSD die!?! ****! no cause it keeps starting. hmm. okay lets turn on the wideband, and,.. i’m getting a flat 18:1, what?! is it working? so i back out the idles on the carb a 1/4 turn, no difference. when i hit the gas it runs down to 12:1 and then dies, but restarts every time. fuel filters look good, the pump is new, but those lines look,.. aha!! there’s a kink in the feeder side and its a rubber section so i readjust it. truck is running good, idling at about 11.5:1 after putting the idlers a 1/4 turn back, yay! i would have wasted way more time troubleshooting if i didnt have that wideband, The End .
4WDKC
Southern Florida
Kacy
11.5:1 holy hell, why so rich?
Isn't 14:1 optimal? We are talking about AF mixture right?
74 Shortbed
A/F ratio is 14.7:1
A/F ratio is 14.7:1
Yep, Yep, I member now now that you mention. I was almost right. Many don't know I was the bad guy in Cali for awhile. I did the training course and ran smog tests. I was the guy that could either make or ruin your day with a PASS or FAIL !!! 14.7:1 was a big one to remember when the CO and HC weren't right. To rich fail HC's, to lean, cause a lean misfire and fail CO's.
77MarshallR
