What Transfer Case Is This??
Battlac40
New Mexico
James
K1500 Sierra Classic
Was looking at a '76 today with a th400 and this behind it.
It was a full-time 4x4 truck but the shiftier doesn't look stock and the knob has a 2hi selection in the middle just below the neutral position.
Help? 203, 205, 208, full-time? Votes?
CSFJ
That appears to be a np205.
That is an NP205 part time case, and the speedometer cable is disconnected.
Why do you think it is full time 4x4?
It does appear to be a NP205 by the shift linkage but NP205 is Part time. NP203 is Full time.
Battlac40
New Mexico
James
It was originally a fulltime truck has the stickers all over. Didnt have a tag on the case and I'm really more familiar with 208s
CSFJ
As far as I know, the 205 is the ONLY one with the small circle that has three bolts between the main centerlines. the np203 would have a protrusion on the forward side of the of the output for the front diff.
Battlac40
New Mexico
James
Thanks you guys :grd:
Battlac40
New Mexico
James
I wanna buy it!
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
Definitely a 205 as said above the 205 is the only one with that little cover.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
And it has that crappy slip joint tailshaft thingy. But still one the best TC out there. You can twin stick 'em.
If behind a TH400 it would have the 32 spine female I think ?
Battlac40
New Mexico
James
"crappy slip joint tailshaft thingy"?
The tailshaft? Is there a good upgrade; the SYE right?
Where do I score One of those?
rpcraft
Robert
LS 6.0 364 CID
You can look up the parts for a SYE online. Check offroad design or advance adapters. I think you could also find old parts for a standard setup but it might be best to go with new parts rather than old parts.
Dougnsalem
So what exactly is wrong with the "crappy slip joint tailshaft thingy", compared to the other?
rpcraft
Robert
LS 6.0 364 CID
it leaks when the driveshaft comes out, as compared to a fixed yoke does not. ON the trail or if you wheel hard that can be a big problem. Other than that, for daily driving, you don't really need to concern yourself.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Thanks Robert,
on hard core trail rigs with long travel shocks/suspension a slip yolk off the Tc just dosn't have the strength when the rear axle is fully drooped. There might only be a few inches of spline shaft left inside.
Folks like ORD make slip joint eliminator kits which is a shaft and seal ring. Then your choice of yolk and a CV joint. Then you can tip your rear axle upwards pointing it at the yolk. It's very nice.
A reverse shackle device drops the rear of the leaf lifting the truck, and also rotates the rear axle to point in generally the way it needs to be. Can fine tune with degree shims between leafs and pad. Dropping the rear of the springs also does a few other things too, it moves the rear axle forward and some say it improves the action of the suspension. The axle's path of bump compression is improved. But this is subjective or imagination or ********... or true.
Slight deviation off the simple Tc I.D. question but this is impertant stuff guys.
Scandia
