What is this wire? It burnt threw.
GunMan9
Yorktown
Brandon
I can not find the TVS anywhere for sale online, would they call it something else
chengny
Is this it?
If so - the single wire into the fuse is 16AWG.
GunMan9
Yorktown
Brandon
Yes that is it. Is the other part the EFE/DISTR TVS
GunMan9
Yorktown
Brandon
I also do not have an ERG because it was taken off when the edelbrock 600 cfm carb was put in. Doesn't the TVS have to do with the ERG
GunMan9
Yorktown
Brandon
Ok ya that's what I have been seeing. Just didnt know why there are 4 ports when the stock one has 3
chengny
I think this one operates the EFE valve. Like I say without an emissions code we're just guessing.
This one looks like it's in the thermostat housing - correct?
Do you have another TVS - one screwed into the intake manifold.
You need to take pictures from further out.
chengny
That's what I was wondering - 3 or 4 ports?
That 3 port is harderr to get.
GunMan9
Yorktown
Brandon
It is right infront of the carb. I have the 5.7 V8 350
GunMan9
Yorktown
Brandon
So a four port won't work? Could I plug the middle valve?
chengny
This is your broken valve OEM part # 3055378:
This is what shows as GM part 33055378:
The part number is visible on the cap and is the same as your image.
Thread Size - NPT: 1/2" - 14 Thread; Direct OE Replacement;Number of Ports: 4; Number of Hose Connectors: 4; Hose Size - Inches: 3/16"; Contents: Ported Vacuum Switch
Alternate/OEM Part Number(s): 212108, 3055378
If we are missing something, pull the vacuum hoses off the switch and post an image.
I have to agree, the TVS that you show looks like a 3 port (triangular pattern, 2 low one high) with a rear vent but the internet doesn't agree.
Oh how I hate that damn internet!!
GunMan9
Yorktown
Brandon
Yes it is 3055378
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
One of those may be a vent.
GunMan9
Yorktown
Brandon
Ok here is another what is this for?
chengny
I'm color blind, but if it's orange and you have (or did have) a TH400 transmission installed - it's the lead that goes from the switch on the gas pedal to the detent solenoid.
3dbello
