Termite_Delight
Lanark Ontario Canada
K2500 K2500
350 L33
Send some pictures after you get the paper peeled off. I’d like to see that fender painted something other than the middle body color.
I was going to paint the fender all green, but I think i like the two tone better.
Has a 70's vibe to it, I like it. Is there going to be any pinstripes or something to outline the two-tone?
78C10BigTen
pennsylvannia
C10 BIG TEN
I know its not period correct but i would have continued the same 2 tone across the fenders. I also think the body trim would set off the two colors nicely
I was thinking of a 3/16" black pinstripe. Thoughts?
Hmm. Personally, I'd maybe use a black/silver combo stripe to kind of mimick the stock trim. A variety of widths would work in my mind.
I think a simple black stripe could work as well, especially if the interior is black. With a tan interior, a shade of gold or maybe even a shade of yellow could work.
Termite_Delight
K2500 K2500
350 L33
It does have a tan interior... I didn't think of gold or yellow... :)
Finished wiring up the relay kit for the passenger door window motor on the dually. All that's left on that door is getting the interior panel back on then time to attack the rear doors.
86Apache
Banned
WV
Marvin
C10's ,K20
250 six, 350's
Before the cold snap, Painted the tail light housings, (that the PO apparently found too difficult to remove or mask before his cheap carmine red paint job) in a bright gloss white.
Kind of an experiment to see if the white is any brighter than the factory silver.
As soon as we get back up to just darn cold, instead this freaking freezing, I will update with my opinion on the white.
Preston
Mechanicsville VA
Preston
I picked up my driveshaft yesterday for my 85 Silverado I put a th 400 transmission behind my new 350 this transmission came out of a mid 60’s GTO had to use an adapter (so much for keeping her original) anyway we will see. Well it didn’t fit, my father in law always told me to measure twice and cut once. I will try and post a short video to explain. Today it’s back to the machine shop, can’t find the video drive shaft is 2” too long, to be continued.
KilgoreTrout
Pennsylvania
Dylan
350ci
This past weekend I did new headlights and misc bulbs (all the lights finally work!), coolant flush (ugly), new radiator and cap (radiator was cracked in a couple places), and thermostat.
I also tore out the driver's side inner door panel to start figuring out why I don't have power windows or locks. Turns out I've got the voltage to the switches, so I ordered new switches (they were really corroded, one didn't work at all, and one was physically broken). New air filter, etc.
I also ordered a new battery holder and a r/f inner fender.
Hopefully this weekend I can do those two things, along with manual lock hubs, bearings, input seals, and front u-joints.
I've never seen ujoints that looked this bad before. They should be super fun to get out (any advice appreciated....haha...)
It's amazing what 15yrs of sitting in the side shed of a barn will do.
I wouldn't be doing any of this without a solid frame and almost no body rust.
84 C20
Dallas, Plaestine, Gun Barrel
scuddy
350 sb
fixed the #@$%!!*&%## out of the wiring for the window. it's now in pieces in the driveway, back yard, on the roof.....the drivers window is the bane of my existence. cant figure out why the window is jumping out of the track.
did get the new grill installed. need to tack up some additional tabs for the bottom anchor points but it looks good.
adhkjashda
