Ray1988r20
Missouri
Ray
R20
Dude, that's AWESOME! Can't wait to get the rear done, so it sits right. I'm not big on the " Cali style" the kids now days do. I'm 4 1/2" lower in the rear. And, I'm still figuring out the website.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I have a Super Lift shackle flip on mine with a 2 " add a leaf. The kit came with a 4" block well I'm not a block fan that why I did the flip. You should start a thread in the under construction section. Project Willy Lee is mine.
Ray1988r20
Missouri
Ray
R20
I tried doing that once, I've got more pics of the process, I'll try to figure it out, and I'll definitely check out the flip you did. I'm gonna attempt to build mine myself. I've got blocks and add a leafs under it now, but like you, not a block fan. Unfortunately I have to do work for the railroad now..... I'll be around later.
radio2000
South Carolina
83 and 88
83 C10 and 88 R10 Burb
started polishing chrome on the '88 Burb
NOPHO84K30
north phoenix
justin
1984 silverado k30
K30 dana 60 corp14 ff
454 sm465 np205
I finally got to get the fitech efi on last week so far so good only problem was throttle return spring i had is to tight like pushing a diving board. I put a lighter one in and its not going in to idle so i ordered a new adjustable one gets here tomorrow.
radio2000
South Carolina
83 and 88
Which one did you go with?
Any other problems? Advice?
NOPHO84K30
north phoenix
justin
1984 silverado k30
454 sm465 np205
Went with the 30002 600 hp one with fuel command center. Only other thing i can think of is theres no ac wire on this one which would be nice. Ive had it die on me from braking with the ac on too much drag on motor i guess ac drops idle to 500 600 rmp and with some resistance from power steering pump killed it... hydro boost ... itd be nice to have it jump to 1000rpm with ac on. The next mod up has ac wire i think. Im going to put it on the dyno next to my work in a few weeks to see where its at and where it should be. Dyno comp is one door down from me..
87scotty
Central il
Andrew
V20
5.7 for now
They are in my thread....but here is a couple.
This looks hilarious please drive it aound like that
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
It's been bagged front and back...
The total fabrication time took me four days to complete. Now it rides smoother thsn it did with the static drop.
74 Shortbed
Fixed the banging noise in the Burb(loose converter bolts)put on a new pan gasket and bolted the exhaust system back on..
Camar068
10 yrs Air Force
got some pipe bent/cut to run from fuel tank under bed to DS tail light for the filler line. Now to find a 2" to 1 3/4" hose adapter. Prolly go back to shop and have them make one out of metal and weld it on the pipe....be fewer clamps that way. May run a boat 2" fill and a separate line for the vent in the same area. Boat because it's a smaller cap. Limited space behind light.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
I added PS fluid to the res...
but, I do this every two days. Baaad leak and too busy to pull the pump. It's helping keep the dust down in my back alley.
Camar068
10 yrs Air Force
when you do fix it, go ahead and flush it out a few times. 'Course with your leak it might be pretty damn clean.
TheSquareGuy
Montana
Wyatt
What was your process on this, my truck has sat for awhile and could use a little extra love
Sent from my SM-G900V using Tapatalk
88SQDRW
