Speakfordadead
Woodland WA
Jeanne
C20's Camper Spc/Sub
350 Targetmaster/454
Picked up my headers from being sandblasted and repainted with flame proof paint. Hope it holds up.
Caps coatings..... Google it
Sent from my LGLS991 using Tapatalk
r67northern
Louisiana
Leland
Suburban r20
I got new plugs, wires, cap and rotor in the r20 this weekend and it's running pretty well now (I've had it for a couple of months, and I've been slowly bringing it around and doing needed maintenance).
I pulled these out, and they seem old to me. When was the last time AC plugs were green?
[/url] by Lineswest, on Flickr[/IMG]
flyboy1100
UsA
me
k1500
305, 700r4??, 3.42 gears
found out my block heater has internally shorted out.....argh! might end up waiting to replace that until later when i do my intake gaskets as well to try and stop the rear intake oil leak.....don't really feel like draining the coolant twice.
so I have been trying to figure out a way to remove the AC belt, but replace it with a Crank/Fan/PS belt and keep my PS/Crank belt. maybe that is just overkill and I should just get the Crank/Fan/PS belt on instead. Gates 7455 seems to fit well for just the single belt option, and I suppose 2 belts is really overkill anyway?
How many miles on the engine? I wouldn't be surprised if those suckers were the originals.
r67northern
Louisiana
Leland
Suburban r20
It's got about 50k on it as best I can tell. It was used a bit for towing by the PO and that's about it. They could well be original, I was looking through old AC advertising, 70s and 80s seems about the last time the green stripes were used.
I must like spending money or something, I bought a full set of Michelin LTX MS/2 for my R20 (same 235/85/16 size). $125 would be a lot nicer, I'll have to try those Yokohama's out next time I get tires.
The good thing about those Michelin LTX MS/2s is they go forever!! I've heard several people say they've gotten 80k or more miles out of those tires.
Yeah, it will be a long time before you need tires.
Ordered parts needed to repair my rear A/C. Will start ordering exhaust parts soon. Also, supposed to be mild next weekend so hopefully I'll get my dumbo mirrors on soon. Been too cold recently to stand out there messing with mirrors LOL
flyboy1100
UsA
me
k1500
drivers side valve cover gasket. I bought the nice Felpro Permadry ones and it melted after 18 months....hmmmm
oil sending unit as it was leaking bad, got an 80psi unit this time to match my 80psi gauge.
block heater, jeesh that is a PITA!!!!!
tomorrow burp cooling system and maybe drive it to work? all of this stuff because of a leaky fuel pump....
Speakfordadead
Woodland WA
Jeanne
Got the massive job done... Three and a half weekends. Tore apart the heater/a.c./vent and literally ended up completely removing everything including the instrument cluster. Holy crap... I wore a mask during teardown and clean up. Took a few days of positive ventilation to get the stink out of the shop. Huge rat nest using all of the stock padding.
Got it all back together. Smells like roses. Had to soak everything in a 55gal drum then scrubbed the heck out of it. Lots of orange degreaser to get rid of the rats body oils too. Now the weenie dog jumps in to go for a ride and isn't digging like a mad man at the heater box. Paint job is next....
Ralph
CT
Ralph
K1500
Just washed and waxed my new to me '85 for the first time today. Pretty happy with the way the paint came back.
robert8096
Goose Creek SC
Robert
Got the underside of the hood sprayed with bed liner. Now I need to find some larger head push pins to hold down the cover. Some of the mounting holes are a little off.
Sent from my ALCATEL ONE TOUCH 4037T using Tapatalk
That's awesome!!! Where did you get that @robert8096?
Put dumbos on the burb and getting exhaust work done on Tuesday
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Got one fuel tank installed, new selector valve in place, and connected my stub hoses from the crossover lines from the other tank to the selector valve. Doesn't sound like much, but it was a PITA.
dancuvelier
