one4fun
Portland, oregon
chris
Why Clips? I'd use some bolts with big wingnuts and fender washers with a rubber pad on them. That will keep the jack from vibrating loose or rattling and making noise. Just run the bolts through the holes in the jack main bar. I've already got my plans for my hi lift, shoevels and off-road recovery kit.
I had something like that in mind. Just using clips as a generic term.
firebane
Calgary, AB
Curtis
Dear mother of god. If you are going to swap from points to HEI PLEASE FOR THE LOVE OF GOD DO THE WIRING PROPERLY.
I was trying to figure out what was going on with my truck in regards to wiring and I noticed today that the wire for the coil 12v had another 12v line spliced to run to the choke.
I remembered reading that using the original wire for the points to power your coil is NOT advised because while the wire will feed 12v during startup it will only provide 9v or so while it is running.
So because of this I ran a entirely new 12g wire from the bulkhead of the firewall to the distributor which well should immensely.
Oh did I mention it was a 1.5hr round trip to buy the stupid terminal for the bulkhead connector... but it is done now.
Skweegle89
Oklahoma
Some people splice the electric choke wire into the 12v coil wire. Somebody on here actually recommended that to me when my choke wasn't functioning properly. I didn't do it, but I think it's a fairly common thing.
firebane
Calgary, AB
Curtis
Yes that is fine.. What isn't fine is using the resistor wire from the points setup because you will only be feeding 9.5v to your distributor and choke when the vehicle is running... :lazer:
Skweegle89
Oklahoma
Ahh I gotcha
79K10
Sacramento,ca
Ryan
350/th350
Try adjusting the ignition switch on the column under the dash.. you'll have to drop the two nuts that hold the steering column in place to see it. Loosen the two mounting screws and adjust the switch toward the steering wheel lil at a time till the engine no longer cuts off.
thanks! i ended up replacing the switch, it looked like crap lol ... starts and stays running now! doesnt turn off till i turn the key off
Bradley8496
Martin georgia
Bradley
Sorry to interrupt but I'm new to this forum. How do I post a new thread and how do I know when somone has replied?
79K10
Sacramento,ca
Ryan
350/th350
click on the section you want and it says "new thread" at top left ... then subscribe to the thread with thread tools, you can get emails every time someone comments if you want
350runner
tx
Ceasar
Awesome! Now you can drive with one hand :)
one4fun
Portland, oregon
chris
Replaced a steering stabilizer cartridge. Had one with a nasty dent.
junkyardog05
Tennessee
Keith
454/ 400 turbo/ NP203
Finally got pictures taken of truck and moved to new job. Owner specializes in cummins swaps.
neginfluence04
Oklahoma
Melvin
K10 Sub
Your priorities are in the right place. :cool:
Was worth it to see this smile
Small pool is to keep the dogs outta the pool
one4fun
Portland, oregon
chris
Made a couple brackets for holding a hi-lift in the bed of my K10. Used 2" x 1/8" flat steel, 1/2" grade 8 bolts, stainless wing nuts, and some 1/16" nylon coated cable to tether the retainer clips when removing the jack. Some etching primer and a few coats of rustoleum for the finished product.
86chevyk10
pennsylvania
chase
I replaced my shocks, starter, horn contact and pad, valve cover gaskets, dome lamp cover, turn signal switch, shift indicator, upper balljoints, and motor mount. Now waiting for the time to do my fender, cab corners and rockers. Guess you can say restorations take up allot of time and money!
JRandle
Verden, OK
Jesse
Chevrolet Silverado
Prepped and painted my headers and installed my newly re done seat!
bigcreek
