Lugnut
Northwest Georgia
Jason
'79) 350/ granny 4-speed, '86) 350/A833 3-speed with overdrive
Wasn't too bad, a scrap piece of aluminum, a couple of hours in the mill, some polishing and some rattle can bed liner for a
little texture. I think they turned out pretty well.
Speakfordadead
Woodland WA
Jeanne
C20's Camper Spc/Sub
350 Targetmaster/454
Red and black looks real sharp..... nice job!
On a date with the wife
flyboy1100
UsA
me
k1500
305, 700r4??, 3.42 gears
Almost finished rebuilding carb today. Lost 2 screws so go to store tomorrow, get 2 replacements, and learn how to tune it! Really excited to see if my choke works since PO didn't hook up linkages correct and now at least it turns!
Sent from my Nexus 7 using Tapatalk
silverscottsk10
trafalgar indiana
mike
Was tracing a short with the gf hanging out and sitting in the drivers seat
She decided to turn on my lights under the dash
Few seconds later smoke comes rolling out of the dash
So glad it didn't catch fire
Irritated about it but I found my short
cbrodine
NW Ohio
Collin
C25
For frame paint I like to use Eastwood's Ceramic Chassis Black...I use the satin finish but they also have a gloss finish. Tough stuff....I just got a couple quarts to do the frame on my 73 GMC when it comes back from the media blaster.
For frame paint I'm a big fan of Por15 :)
Green79Scottsdale
G.R. - MI
Bob
My father-in-law had the frame on his F250 plow truck sprayed at a local marina with some type of marine specific epoxy. That was done at least 10 years ago. Still looks like they sprayed it yesterday, and he only uses the truck in the winter, in all the salt and **** they put down here in MI. If I ever get to that point with my truck, I will be looking into that as an alternative.
Sounds like some good ****. You should figure out what it is and let us know about it.
anubisani
MIAMI, FLORIDA
SEAN
R/V 3500
454 TBI TH400 4:11 gears
you think it could be this or another product like it
http://www.ebay.com/itm/NEW-MARPAC-MARINE-BOAT-Mar-Protect-Epoxy-Primer-Gallon-7-2670-/271326958231?pt=Boat_Parts_Accessories_Gear&hash=item3f2c58d297&vxp=mtr
datto62073
Monroe
Mark
Yesterday my son and I replaced the front t case output seal and installed new ujoints into my new (used) front driveshaft. That was a PITA!!! But it's done now. On to the rear and then easy off the underside to clean everything up.
yeol1
East TN
Joe
Installed a Uniden pc68xl
MadOgre
NA
NA
NA
NA
NA
Replaced the range shift hub and seals in my 241. I gotta say its pretty simple which should equate to a good transfer case.
firebane
Calgary, AB
Curtis
Desludged the front of the block on my truck. Cleaned up the one cross member.
Looking online I now have to double check if I have the short fuel pump bolt because I don't recall see it. Also don't recall seeing the fuel pump back plate.
Will be getting some stuff to clean the top of the blocks to put the 993 heads on.
aaron06
