friscobob
Sutherlin Oregon
Bob
C 10
Re mirrors
Trying to figure out how to keep my mirrors from moving
EVERY time I get in the truck the mirrors have gotten out of adjustment
Help!!!
What mirrors do you have?
raylanr
Campeche, MEX
Franc
Finally got rid of the alteza tail lights.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Looks much better!
v2500burb
Charlottesville Virginia
Jay
v2500
350ci
Frisco
I have these
Frisco
I have these
Have you pulled the chrome cover off to see if you can tighten the nut on the swing arm? Maybe it's loosening up. IIRC, there is a spring that applies tension. Maybe some different springs from another mirror would fix it, or put some locktight on the threads and tighten the nut a couple turns to stiffen your spring tension.
datto62073
Monroe
Mark
**** happens. If you get 20 years outta these new Warns then it'll be worth it. :waytogo:
thats the plan. all metal and a lifetime warranty, i cant complain, exept for the price......
datto62073
Monroe
Mark
well i went over to the boneyard and found some cool stuff. well cool to me anyway. i picked up 2 better condition clearance lights, a chrome trim side marker (mine was missing the trim), a latch for my slider, and a OE tape deck. i hope the deck works, but if not i always have my SONY. now i have 3 working clearance light, out of 5.
cbrodine
NW Ohio
Collin
C25
went through my HEI dizzy....new pickup coil, condenser, adjustable vacuum advance module, new Pertronix module and coil all topped off with a new cap and rotor. Also shimmed the dizzy gear.
Stabbed it back in yet? How's it run now?
the skull
central OH
andy
K2500, M1008
I put intake gaskets on mine yesterday, cleaned up the sweet GM aluminum intake, fixed the horn (maybe), it has corrosion problems. Also put a single din stereo in it, with a Small box behind the seat. I think this is the first time the truck has ever had real music, it had an AM radio and a dash speaker when I got it last year. Still needs an overflow tank, I think its cracked. My fender leaks coolant (weird)
heffalump
Lafayette ga.
jeremy
2500 suburban
Haven't done much to the suburban lately, most of my free times been spent on the 48 project. I did work on it a little yesterday, finally got the inside all cleaned up, fixed the CD player and added 2 10 inch pioneers in the back to replace the blown factory ones.. Surprisingly the front ones still sound pretty good..
NOPHO84K30
north phoenix
justin
1984 silverado k30
K30 dana 60 corp14 ff
454 sm465 np205
Found a pair of chrome headlight bezels at a salvage yard $15 . Not bad I hit a branch out in the desert broke one of them. Did a clutch centerforce ll fighting some leaks in front a sm465
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Got a 5' firestik II and wrapped it with an rgb led strip. Guesstimated wrong with the length of the strip. Need to order some more up, seal it with clear heat shrink, and make up a mount.
At the moment, I've got myself 3/4's of a 5' light saber.
cbrodine
NW Ohio
Collin
C25
Havent got it back in yet, nor have I fired up the motor for the first time yet...getting there though!:cheers:
hey mister
