- Dec 7, 2010
- Southeast PA
- Paw Paw
- Chevrolet Tahoe LT
- 5.3, 4WD
Sent from my iPod touch 4th Gen using Tapatalk
Started driving it daily, spent a couple hours trying to figure out where the vampuric battery drain was coming from.
I put ammeter onto battery with a buddy and went circuit by circuit removing them until drain ceased. Turned out to be my cb radio, amp and p.a speaker. Somehow it was left on and was firing up the amp to the p.a.
I had a mean accel bog. Mech fuel pump was leaking thought it might be why so put a electric pump on. Didnt fix it. Said ok lets rebuild carb did it still craps out. Sh..t ok start pulling plugs got to #3 plugs good but header burnt it up under the heat sleave.. replaced wire runs like a champ again . But found check ball from carb on floor so tore it apart again put it in runs better then before ..oh yah accel plunger was torn. It had black plastic from pick up sock from old tank and two inches of the air cleaner top gasket that got pinched of stuck in the top of the secondary butterfly. So glad o figured it out . I tend to just start replacing things without really finding the issue first. Its spendy but 3/4 of the trucks new by now lol
I let the C30 run for a while today and took her for a spin around the block.
The CC I look at it and curse at it, and went back into the house. LOL
Frank! You're alive!
I understand how you feel about the Crew, been there, done that, lol. What's giving you fits on it these days?
We haven't figure out why the rear brakes don't get any brake fluid, after replacing the proportioning valve.
