Water leaking in cab of 83 c10
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Anyone got a clue why water is getting inside of the cab?
The carpet is soaked!
It's under the driver's side floor where the seat is, and at the passenger side floor board.
Hester core isn't leaking, it's been replaced.
Sent from my SM-G965U using Tapatalk
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Usually the windshield gasket in the front. Possibly the rear window gasket for under the seat..
crpntr78
Missouri
Pertaining to the passenger floor board, Check for leaks around the vent in the kick panel. Thats where I found my leak. Just have to take it out and clean out any debris and reseal with a good caulk.
MikeB
North Texas
Pictures below show the cause of the water leaks my truck had. Of course, the water ends up pooling under the carpet or vinyl mat and soaking the carpet pad.
If you can see signs of water leaks on the inside of the firewall up under the dash, the problem is cracked and/or thinly-applied seam sealer underneath the cowl. In my truck, the signs of a leak were very easy to find on the drivers side above the fuse panel, There was also a smaller leak on the passenger side to the right of the heater box.
The fix is to rough up the seam sealer surfaces, and then apply a new coat of seam sealer. (if you can remove the old stuff, more power to you!) I really like the SEM product. On the inside, I used fiberglass mat covered with POR-15 to seal the rust-through spots on the driver side. The hole on the passenger side was smaller, so I simply used seam sealer.. Not a professional fix by any means, but I have seen the fiberglass mat/POR-15 fix last >15 years with no rust-through.
Passenger side
Deep dive into driver side
Inside damage -- some near rust through in places above what's shown.
I also had really bad leaks past deteriorated kick panel vent seals. And no, the passages were not clogged with leafs or debris. I think it was just a poor design that allows water to run too close to the vent.
BTW, water leaks, however minor, are a good reason to use 3/8"-1/2"closed cell foam instead of jute or felt under your carpet or vinyl mat. A vinyl mat works great for me because, hey, it's a base truck.:)
mikejeden
