Vacuum lines
jamie916
Sacramento
Jamie
Hi guys I have an 86 k10 but the motors a 70s sbc 400 but I can’t find any digrams for the vacuum line that actually match mine it’s has all the smog equipment any help is appreciated
Question, I see you're from Sac, Cali. So do you live in area where smog testing is required? Cali emmisions is going to be different. Do you have a Cali emmisions truck? Because of of your GVWR and if a Cali truck it does have a Cat Converter right? And an Electornic feedback carb with a CCC (Computer Command Control) system for the E carb and ESC (Electonic Spark control) as well as EGR and probably a AIR pump aka Smog Pump with a dirverter valve right??? So I doubt you want to tell the smog testet that it's a 400 from a 70's truck if they don't figure out or you might have to see the referee.
So if all I'm suspecting above is true, we need to find an 86 K10 Cali Emissions Vac Diagram and make sure it's set up that way so maybe the smog test station wont think nothing of the engine that's in it. And hope it's in good enough shape to pass tailpipe sniffer test.
Had it been a K20 or K30, you might have made it without a Cat. These years the difference of emissions on the trucks was very different based on GVWR. 3/4 tons and above got by with much less than the 1/2 tons. Also passed with a dirtier tailpipe sniffer test.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
Welcome from Grass Valley. Definitely don't tell the smog person it has a 400. California does not allow you to install an older engine into a vehicle, only same year or newer. If you don't know what engine the truck originally had, LMC truck can at least decode the VIN for you (Link #1). GM Heritage Center for $50 can get you the original invoice for your vehicle. This helps determining if you have a Federal or Cali truck for smog.
I found Autozone has diagrams for emissions. They are useful, but more difficult to read due to the fact they are black and white. I was able to figure out my hose routing from the sticker on my OEM air cleaner. The third link is to the diagrams. 1986 V-8's start at #117.
http://www.lmctruck.com/icatalog/cc/full.aspx?Page=9
http://www.gmmediaarchive.com/?page=1#
https://www.autozone.com/repairinfo/repairguide/repairGuideContent.jsp?pageId=0900c1528004c3cb
joseph916
