Torque rod bolt broken in bell housing.
Phil Black
Central IL
Phil
I have an '85 K30. Looks like the last time the transmission was serviced, jackwagon snapped off the head of the bolt supporting the torque rod to the transmission bell housing. Not much room to work there. There is a bit (not enough to grip with vice grips) out of the hole. Looking for suggestions to get bolt out without having to drop transmission. Right angle drill with a left twist drill bit maybe?
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
That's what I would try. They're usually not seized in, they break from stress. So once you get it moving it should come out.
Phil Black
Central IL
Phil
True. Was able to spin it out tapping it around with a flat blade screw driver. Not sure the bolt was even the correct size. What is it supposed to be ? guessing 5/16?
QBuff02
Central IL
Quincy
If you're talking about the rods that go from the engine mounts to the aluminum converter cover the correct bolts should be if I remember correctly a 7/16 bolt about an 1 1/4"ish long. That's the way they are on my '82 anyway.
Phil Black
Central IL
Phil
The single bolt that secures the torque brace to the transmission case. I have the 2 bolts for the rod to transfer case but need to make sure I have the right size for the transmission end of the rod.
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
I think it's 3/8-16 but for length,... 1-1/4" or 1-1/2" but I don't really remember.
QBuff02
Central IL
Quincy
ooooh.. Lol Misunderstood your original post, I was thinking from the engine to trans.. you're going from the transfer case up to the backside of bellhousing. Those are 3/8-16 and that particular one on mine is 1 1/2" long. It has a couple of oversized flat washers on it too, kind of helps spread the load across the eye in my opinion.
highdesertrange
kalifornia
mike
k30
3/8 x 1 1/2. it's supposed to a flange head so no washers needed. highdesertranger
73c20jim
Tombstone, AZ
Anyone have a picture of this support rod?
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
I'm sure I can take one for you tomorrow if somebody here doesn't beat me to it. Are you looking to add a transfer case to your truck?
73c20jim
Tombstone, AZ
Might be. Need to see what it does. Maybe I got one already.
73c20jim
Tombstone, AZ
OK for 4 wheel drive.
I got 2wd.
Thanks.
Edward Maxwell
Right side of WA
Edward
What is the real purpose for this rod, does it work? I had help with my swap and the person swore til he was blue in the face that it was the worst idea to come out of GM in the last 100 years.
SDJunkMan
Black Hills of South Dakota
Jeff
I snapped the bellhousing in half on my 80 while plowing snow. Was told that it was because the P.O. Removed that rod and the ones that go up to the engine mounts. Haven't had any trouble with the replacement tranny now that the rods are there. Of course I worked the truck very hard while plowing.
Jonny1981k1500
