Tire and wheel change
Ron Sebastian
Vero Beach
Ron
Custom Deluxe V10
Ron I'm worried about your tire clearance. I don't see any. Do your rims have less than 4.5 offset?
And something else... it looks like stock front springs at half mast.. I mean negative arch. Yet your truck looks lifted? Illusion?
The 33's on 16" rim clear fine been driving it like this for years. My problem is I want that lifted look but with the 15" stock rims. Can't find a tire bigger than 30X9.5. I'm afraid they would look too small. The truck drives great with the 33's.
WebMonkey
Missouri Ozarks
35x12.50 on 15" rims
245/75R16
good luck
Ron Sebastian
Vero Beach
Ron
Custom Deluxe V10
For clarification, my stock rims are 15x6. Very limited width choices. Hoping the 16" rims are good.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
So you're obviously not offroading then.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
They make this in a 33x10.5x15
Ron Sebastian
Vero Beach
Ron
Custom Deluxe V10
10.5 is a problem with 6" wide rim.
Washington
What is puzzling, 6 year old tire/rim setup. Did they run out fine until recently? In many years, many vechiles and many sets of tires, I’ve never had a tire just go bad or lop sided after however long….
Except for 1 Firestone Destination MT, maybe coincidentally. And it wasn’t bouncing or “out of balance”.
It caused the truck to pull to one side. Ruled out alignment. Swapped front tires back to the rear axle. Problem solved. Rotated back to the front again later and no more issue. Dunno if it slipped a belt and then corrected itself or what , but tires don’t just go out of balance sitting there.
Something to think about?
And it’s even more unlikely that the issue is the rims.
Washington
You can get by just fine with that combo especially tall tire with lots of sidewall height. Have run many 12.50 tires on 8” rims. Same thing.
Personally, not my favorite “look”, but not obtrusively ballooned.
And not ideal for hauling heavy loads but not prohibitive.
Truck to the left is 315s on 8” wheels.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
I don’t know if it is or isn’t, but many folks (myself included) have run 11.25” wide 285s on a 6.5” rim without issue. I have a set of Yokohama geolanders on stock 16x6.5” wheels right now.
Ron Sebastian
Vero Beach
Ron
Custom Deluxe V10
Grit, I thought the wheels were ok, not the best ride but I figured MTs what do you want. When I rotated fronts to back, the vibration started. I'm sure I could drive it a few thousand miles and they would round out, but I only drive it about 3K miles a year. I could rotate them back sure but the cupping won't get better.
Ron Sebastian
Vero Beach
Ron
Custom Deluxe V10
There's about 15k miles on these Firestones.
Ron Sebastian
Vero Beach
Ron
Custom Deluxe V10
According to who? 10.5" section width works nicely with a 6.5" factory rim.
Bucket, reading the data on the manufacturer site. Maybe it just a suggestion, I don't know if it's gospel and very bad things could happen. I don't mind pushing the envelope when I have to, not sure I need to in this case.
cartunesguy
