The Bench Seat...
87ChevyR10
Kansas
NA
NA
NA
So, I am curious, who here has had a shop rebuild their bench seat? The driver side of mine is sitting so low, I look like an old man who can barely see over the steering wheel and I am 6 foot 2! The cover is fine, just need the driver side rebuilt. Any ideas on cost? Thanks!
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Just get a seat from a yard with a good cushion some hog rings and hog ring pliers and have at it. It isn't hard to do. If it's vinyl sit it in the sun to make your seat cover a bit more flexible. Just st be careful removing the cover your keeping. You can practice pulling the cover off the replacement seat.
Crispy
Carbon County, Pennsyltucky
Suburban V1500
You have a few options here and prices vary on location really but having a shop re-foam the seat would probably at least $200 where I'm from.
If I remember correctly the seat bottom is one long piece across so if you want to service only your driver side then you would have to cut and graft in new foam. If it were my vehicle I would order seat bottom foam, hog rings, and pliers online to try the install myself. I would also get some burlap to line the bottom where the foam meets the spring to help reduce wear on the foam.
cooperhw
Mesa AZ
Wayne
C-10, K-20, C-20
5.7L
Open it up and see what is failed. might be some broken springs, seat foam (buns), put it back together.
yevgenievich
Viktor
sad
very sad
less sad
I have done a fix before by replacing a tension wire and stuffing foam from below before. Cost was zero due to access to wire and foam.
donnieray
Talks to dogs and trucks.
Roanoke Rapids NC
Donnie
86 C10, 84 K10 MM7 NP833 option truck, 85 K10.
350,355;350.
I reupholstered one with foam and cover from LMC. Turned out nice and wasn't real hard.
spanky55amg
I'll give u $5, a hardy handshake, & 5 fish sticks
Dallas, TX
Spanky
C10 Short Fleet
V8
I dont have hog ring pliers and have done seats while I worked in the shop. I wish I had bench to rebuild. But I would look into a local shop to recover, thats just me. I want something different like houndstooth.
Kasey 1977 K10
Kasey
I had mine rebuilt and recovered at a local shop here in Hillsboro, OR. It was a bit costly ($400) but I love the end result. They fixed some springs, replaced some of the cushion and recovered it based on an idea...http://chevy.piratesproductions.com/2016/05/bench-looking-good.html
seabee
South Carolina
Lee
Had mine redone and shop found broken springs.The shop bench out a had welded . Turned out good but should have had cushion replaced after sitting on it for 30 years
Evil Bob
NY
Adam
Just had mine done a few days ago here on Long Island (land of everything expensive)... Total rebuild, new springs, frame had to be welded, new foam, and new vinyl with a chevy emblem sewn in. Cost was $500 cash and I am super pleased with the results. Oh and he added baby seat latches for my two boys car seats.
Yes those are alignment marks for the bowtie... they wiped right off:)
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
I had my entire bench seat rebuilt...springs, better padding and even had the sides and center bolstered a bit more than oem. I upgraded from the vinyl to material. The entire job took the local shop two days and cost $265.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
How ever are you gonna get a console in there?:happy175::happy175::happy175:
87ChevyR10
Kansas
NA
NA
NA
That looks great! $265 ain't bad, either. I'll have to do some checking around town and see if I can get a similar quote somewhere. Thanks!
74 Shortbed
Looks great, I like that material...:waytogo:
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Yeah, I can't get over how good that material looks. Worth every penny.
87R10_Cruising
