86Peter454
- Nov 13, 2017
- Missouri
- Matt
- C10 Scottsdale
so im rebuilding a known good (or so i thought) th400. it came out of my 72 c20 it worked just fine when i parked the truck.
took the thing apart and found that there was a shift kit put in it at some point (who new) and they removed the 2-3 accumulator spring out (thats fine i was going to do it anyway)
well the c clip that holds that piston down was broken (i found part of it leaning against one of the check balls in the labyrinth) and i guess that chewed the **** out of some stuff. here are some pics.
https://imgur.com/a/paPuK
(its a link to an album have descriptions under the photos)
basically want to know if i just clean up the burs raised by the broken c clip and get a new cclip will that be okay? or do i need a new valve body and case?(pls say no)
also how do i keep the c clip from breaking again?
thanks for any help!
