Stiff throtitle pedal
Jerry phillion
Saginaw, mi.
the pedal on my 87 TBI 350 R10 is quite stiff. have searched to no avail. Installed new cable .
No help. Disconnected throttle cable and with tv cable connected, pedal is easy to push.
Disconnected throttle cable, pedal is harder to push. Must be throttle shaft springs
Or something else. Any help much needed.
eskimomann209
Modesto
Marcus
Mine was always hard to push too.... I just got used to it. I mean taking on of the return springs made it easier. But I’m not crazy enough to drive with one o_O
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
I’ve noticed the same. It’s definitely the TV cable in mine, but my car, which has the same setup, is as easy as a new drive by wire vehicle. I just deal with it. It’s manageable, but it’s weird that it’s like that on the truck. Is your TV cable straight, or is angled a little to the side because mine is on the TBI truck. Weird.
73c20jim
Tombstone, AZ
Make like a tree and Leave (leaf).
Get it?
CSFJ
Get it?
Pretty sure he was quoting from Boondock Saints. Lol...
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Close, it was Back to the Future. You get me, though.
don
ohio
don
v10
350 tbi
Kasey 1977 K10
Kasey
After my Sniper EFI swap my pedal was very stiff and touchy. I installed a throttle lever extension and it made a huge difference.
https://www.holley.com/products/fuel_systems/carburetor_components/brackets_and_linkage/parts/20-14
don
ohio
don
v10
350 tbi
Try checking the throttle body base gasket . Mine was rubbing the throttle plates and made the pedal very hard to push. I used a spindle sander to make the holes a little bigger and it works great now.
mattyb
