- Oct 30, 2019
- Downingtown, PA
- Wayne
- Jimmy
Most likely the air pocket moved through.
Filling many newly assembled engines through the radiator with a well sealed thermostat can create an air pocket in the upper part of the engine. The heater core also could have an air pocket too. One way to avoid the air pocket is to fill the engine through the open thermostat hole. Then add the the stat, cover and upper hose. Finish filling through the radiator.
Also you can sometimes remove trapped air by pulling off the heater core hose at the manifold. Easiest way I have found is to add the bleed hole to the stat if it does not have one.
Note: Diesel engines should always be filled after pulling a vacuum on the cooling system, then let the vacuum draw the coolant in. Air bubbles next to the outside of the cylinder walls in the cooling system of a diesel can cause cavitation. Any engine can be filled this way, but most, do not have a vacuum fill tool.
