Steering "whatchamacallit" question
Surffly
Long Island
William
What are the two "lever" or arms on the left of the picture?
I ask because some things on the truck have gotten rather ghetto over the years...like the coat hanger plug wire holders....
marks86
Latham, NY
Mark
12v Cummins
I know one of them is for the automatic shifter lever
Surffly
Long Island
William
Truck has had both a manual and an auto at different points in its life.
Unsure how it was new.
Now has a hurst floor shifter.
Trixxterr
Tx
Gary
C10 Silverado
Pretty sure, when used in a 3 on tree, both levers are used, in an auto only the bottom is used. My 72 has the same set up, it was, is, will only be an auto..from factory
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
For a manual shift. Automatics never used two, automatic columns only have one.
Surffly
Long Island
William
So the truck may have had a colum shift manual?
RetroC10Sport
Jay
pontiac aztek
Most definitely. I can't see someone actually swapping in one of those columns.
You never know though. Column could have been jacked at some point, guy had that one behind the garage already so that's what was put in.
Probably originally a 3 on the tree truck though.
...My 72 has the same set up, it was, is, will only be an auto..from factory
If that's how it is, someone at some point has done some boonrigging. Your shifter must be really goofy... pull it one way to shift through the gears, push it the other way and nothing happens when it goes up and down.
Trixxterr
Tx
Gary
C10 Silverado
I honestly do t know anymore, it didn't shift weird or anything. Just like a normal auto, I never knew what that extra arm was for, asked a mechanic friend and that's what is was told, back when I inherited the truck in 93. But, I know for fact the 72 is auto from factory.
92 X-Ray
