Steering Column Bearings - HELP
jka251
Alabama
Keith
I just bought my 84 K20. The steering column was loose and it was the common 4 bolts needing to be tightened and loc-tite applied. I did that but in the process the inner and out steering wheel bearings came out. One of them was damaged. I am in the process of trying to put them back in but it's been a pain. The bearings are in pieces and the balls are only held in by grease. I've left the wiring on the column attached and have the steering sector where the turn signal switch and ignition tumbler are attached to the wiring as well. All of this is hanging loosely. I'm having a hard time putting the bearings back in and getting them to stay in place so I can put the pivot pins and everything else back together. Does anyone have a good method or re-assembly of these? Also, is there some type of aftermarket one piece bearing that I could use in place or cross reference a one piece bearing? These are extremely aggravating. Any help is appreciated.
77c102door
Newark
Harjeet
What I ended up doing is buying a column rebuild kit which had new bearings and then bought bearing and race installer. Worked like a charm
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
MrMarty51
Eastern Montana
Martin
Yeah, welcome to the GMSB forum 251.
74 Shortbed
Welcome to the site.
Welcome to GMSB.
I'm almost certain the only way to get those bearings is to buy the column rebuild kit.
jka251
Alabama
Keith
Thanks for the help and the welcome. I did end up buying a rebuild kit. The new bearings were still a pain to install but I did a little polishing on them and got them in. Appreciate it guys.
cmoore
Florida
Chad
V3500
Where did you purchase the rebuild kit from?
Big Chip
Michigan
Kevin
C35
Well the way he’s trying, you’d think he has the Arc of the Covenant
Maybe so and it just so happens that's what I'm looking for. On the plus side, you have accomplished your goal! Congratulations!
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Sweeeeeeet!!!!!!
At least it was an actual post this time. But now I'm curious where the kit was bought too.
Lol, and what he wants to sell.
PMPlocheck
