speedometer issues
NCTyphoonKid
Trinity,NC
Korey
Silverado R10
I've taken the new cable off and greased it and I can't find where it would be binding at
Georgeb
Wisconsin
George
K10 Burb Z71
Make sure it is connected properly on the back of the cluster and not pushed up tight there. In other words make the keeper on the cluster end do its job. I used to gently tug on the cable sheath from under the hood once everything was back together. It helps if the grommet is lubed up with some silicone spray. Don't pull too hard!
NCTyphoonKid
Trinity,NC
Korey
Silverado R10
Ok I'll turn the cable and get it set back to 0 and pull it out tomorrow and see if that'll correct it
Georgeb
Wisconsin
George
K10 Burb Z71
Did you just say you needed to set the speedo back to zero? If so you may have a speedo issue.....
NCTyphoonKid
Trinity,NC
Korey
Silverado R10
Yeah when I installed the cable it turned all the way to its stopping point and has stayed there
NCTyphoonKid
Trinity,NC
Korey
Silverado R10
still having issues with this does this sound like something's wrong with the speedometer? Odometer isn't working either :shrug:
NCTyphoonKid
Trinity,NC
Korey
Silverado R10
bump should I buy another speedometer :shrug:
yevgenievich
Viktor
sad
very sad
less sad
You can manually play with the spedo and see if needle will bounce with your movement. If it is stuck at 100 with cable disconnected then binding was likely in spedo gearing it self and will need to replace the spedometer. Good check with the cluster out is to drive and see if the inner part if the cable spins.
Squarebody322
