speedometer question
Wannabe
Streator, IL.
Chuck
Guys, I am installing all aftermarket gauges and I was putting a new speedo cable in when I saw a small box attached to the driven gear, it has offset connections for mounting on the trans and the other is for the cable. What is this and do I need it with aftermarket speedometer? Try to ignore the scratches on the column, I'm not finished yet.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
As long as the new speedo is still a mechanical one - cable driven - that is needed.
It is an adapter for a different gear ratio that is OE equipment.
Camar068
Kentucky
10 yrs Air Force
LS engine or 4l60e transmission?
Wannabe
Streator, IL.
Chuck
According to Equus gauges, it is called a transducer and is not needed with their speedometer.
85sqbod
