Silicone on a rubber gasket?
cramezl
Oklahoma
I never can remember which gaskets you are or aren't supposed to use silicone with.
Sent from my HTC Hero S using Tapatalk 2
bigcountryguy19
Sealy texas
josh
6.2 diesel
You can use silicone if u want to, just snug the bolts till it dries then tighten them up all the way
Don't use RTV with that one, just a little dab in the corners (next to crank, not corners of pan) is all it needs. be sure to use the bolts that come with it too, they are longer.
bigcountryguy19
Sealy texas
josh
6.2 diesel
Are those gaskets that much better than the four piece? I have never used one.
Yes, they are an EXCELLENT gasket especially for the price. You can even reuse them (another reason for skipping RTV).
cramezl
Oklahoma
Nice! Thanks, bucket
highdesertrange
kalifornia
mike
k30
love that one piece is that a felpro? they are reusable. highdesertranger
cramezl
Oklahoma
Yes it's felpro
chengny
The reason silicone is not recommended is because, in some areas of the flanges (mainly the outer four corners), it can act as a lubricant.
This can cause the gasket to squeeze out from between the faces during the tightening process.
prenrag
