side marker
anubisani
MIAMI, FLORIDA
SEAN
R/V 3500
454 TBI TH400 4:11 gears
hey guys are the front fender marker lights on the 73-80 the same as the clearance light on the dually fenders on my 1986. please it will be nice if I get a quick response , since I am about to place an order . Thanks guys.
Carb'ed Vortec 350
My initial response is no. But I am not familiar with all the little differences between the years. I just did a google search and it appears they are different. The older ones are vertical and the newer ones are horizontal. Maybe someone else can give you better info.
anubisani
MIAMI, FLORIDA
SEAN
R/V 3500
I think its the same light they are both vertical on the dually fenders and the front fenders , but I am not sure its the same
theblindchicken
SoCal
Christian
K10 5" lift + 2" BL
350-4, 0.030" over
Do you mean the bulb size? Lens size?
Bulb size: probably the same 194/168 wedge bulb.
Lens size: I'll bet they're completely different since they're half reflective and the other half for a bulb. Also, they look thinner and a little more squared than the older marker lenses.
anubisani
MIAMI, FLORIDA
SEAN
R/V 3500
I meant the lens but I already found out the are the same. thanks
MadOgre
NA
NA
NA
NA
NA
I would have thought so but good to know!
That's something I've always wondered. The lenses have a different reflector design molded into them, but the overall shape and size appeared to be the same.
anubisani
MIAMI, FLORIDA
SEAN
R/V 3500
yea
Kipps5000
