Shackle Flip Lift ???
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Hey BZ, you have any pics of the DIY kit installed?
kleedus
wyo
Ray
1960 threw 91
c10 to k30
350 threw 454
i used two wheel drive front spring hanger brackets on the back ant they worked great its a cheap way to go.(front of the rear spring)
blazer front hangers are the same as two wheel drive also. i think the earlier blazers had the taller ones that are not the same as two wheel drive ones. but can not rememer what year they changed.
the shackle flip does move the axle forward so you will need the easy inch blocks or something similar to move the axle back
dirtroadoutlaw
Florence, MS
k5
Jftr, i have no issues with trailering. No lateral movement issues. Still flex well, with 6" usdr shackles too. A 16' trailer with four quads gives no trouble at all except for the 6.2 being a little slow to get going. Really look closely to how your suspension works then build it how you want it. It's worth the trouble.
ryno13
OHIO
Ryan
K5 Blazer
anyone know if you can use the factory shackle hangers and just flip them upside down and side to side. Yes I'm a cheap ass and don't wanna spend the $$$, planning on a 4" drop box for the front! can you say hill billy?
8T6K5
AZ
L98 350 TPI
Pretty sure, that looks like a factory shackle...
8T6K5
AZ
L98 350 TPI
Heres another one though...
8T6K5
AZ
L98 350 TPI
junkyardog05
Tennessee
Keith
454/ 400 turbo/ NP203
That looks like the ORD hanger could you also use the DIY4X shackle with this set up to beef up all the suspension?
nvrenuf
Mobile, Al.
Yes, the Diy4x shackles fit an ORD flip bracket. Here's a pic of mine; 2.5" ORD flip w/ 6" Diy4x shackle.
junkyardog05
Tennessee
Keith
marks86
Latham, NY
Mark
12v Cummins
How much lift does your rig have?
I looking to lift mine 6 inches and tuck 37x12.50r16.5 Goodyear MTR military tires. Mine is a street queen too.
its lifted 8 inches in the rear and 7 in the front
a shackle flip plus 3/4 ton leafs=8inches I guess
I have six inch leafs in the front and my 37 good years rub at full crank so I put a zero rate block still touches once in a great while but I had no issues on the street with six inch springs and 37" tires...............o except for them being the biggest PITA to balance but that's a hole different story
junkyardog05
Tennessee
Keith
I was looking at doing the shackle flip in the back, 52 inch springs in the front, zero rate block on both axles and a 1 inch body lift for extra insurance. All that together should get me 6 inches of lift. Any thoughts?
marks86
Latham, NY
Mark
12v Cummins
that's exactly what I have except the 52's up front works great looks great with 37" tires
Pugs Speed Shop
