Running an Engine outside the vehicle
legopnuematic
Licensed Junk Dealer
MO
Spencer
I used a $25 stand from jegs to run the 350 from my 79 to break in the cam, worked pretty good, did not try to get away at all. I'm not sure if they have one for a 6.2 or if the small/big block stands work for them but its a inexpensive option.
Ah, you poor innocent young things, that have never owned a vehicle with a crank handle. :D
Oh yes I have. Lots of fun. Gives you a lethal right arm.
idahovette
Weiser Idaho
Perry
K20-K10
It can also break your arm if not done correctly!!
Burban
Bear
Uranus
H
Suburban
It's like driving off road, keep your thumbs out the way!
Termite_Delight
Lanark Ontario Canada
K2500 K2500
350 L33
I prefer to use the electric start... Notice the oil can and felt over the rockers?
Burban
Bear
Uranus
H
Suburban
And now I think about it, this will let me move the engine into the garage to work on, as I can't get the front loader in here. Just put the stand outside, bring the engine over, and wheel it in, cool.
For anyone in the future looking at this, the key is to search for engine cradle, not engine stand.
Burban
Bear
Uranus
H
Suburban
Try upping your lubricity grade, say a 20W50 :D
CSFJ
Gonna lose rpm going to that heavy of weight .
Burban
Bear
Uranus
H
Suburban
Yours revolves?
CSFJ
Never had a girl add a little twist in her stroke?
Burban
Bear
Uranus
H
Suburban
Not thru 360.
Camar068
10 yrs Air Force
I fit an LS 5.3 in one of these as well. Worked just fine. Can't remember where I got it, but it was same price as yours....$25.
Daveo91Burb
Vancouver, WA
Dave
V2500 Silverado Suburban
Vortec 383, modified TBI/4L80e
Sounds like the cradle is a good solution, but for another option start at post #141 in my 383 build thread for simple homemade run-stand that I built with (mostly) stuff I had laying around. Worked like a charm, engine didn't try and lift up at all.
skymagu
