Retrofitting a factory tachometer?
I have the gauge with the fuel gauge and speedometer. But I have a manual and would like a tachometer. I have a gauge cluster in a stripped out C10 on my property that has a tachometer. Is it as simple as running a wire from the distributor to the cluster?
dvdswan
Port Orchard, WA
Dave
Yes. In a matter of speaking. Easiest way is to pull the tach wiring harness from the donor truck as well. Its 3 wires on their own with their own connector.
Green79Scottsdale
G.R. - MI
Bob
As said, for the most part, yes. There are other things that will need to be addressed, but if you have a donor cluster it should be "easy".
Green79Scottsdale
G.R. - MI
Bob
If you have a donor cluster and its a similar year, the cluster swap is easy. For example, from 73-75 the instrument cluster had a mechanical oil pressure gauge and an ammeter, so using a '74 tach cluster in my '75 was a direct swap. However, later years used an electric oil pressure gauge and a voltmeter, so they would have required some wiring changes.
As already mentioned, the tachometer itself has a separate 3 wire harness, with power, ground and signal. Signal wire connects to the tach terminal on the HEI, power to any ignition-switched power source, and then connect the ground.
Originally the truck may have had a tach filter on the signal wire, but it seems to run fine without it. The fliter is a small silver canister mounted somewhere near the HEI distributor.
Garcjay
