Project Mini me
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Looking really good!
Thanks Iowan.
So I looked at pick n pull options in fairfield as it was either that or stockton.
Headed out and it took about 4x hours, but I did stop in dixon to see if the dismantlwr had it. He sounded agreeable, but flaked out so I ended up at pick n pull.
Ended up getting everything on the list...
Iowan
Loud and Proud American!
Iowa
Calvin
K1500
350 crate
Man I wish I had a pick and pull yard near me!
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Rows of cars but not a bad day whether wise...
There she was....I was so over it I never checked out the xl7s...
V6 model lost strut brace, consenser fan, some lug nuts -as some of mine are a little chewed up, both sides adjuster for rear drums, sway bar brackets and bushings... $94
Just got home, so now break time, and shower, then gotta install this stuff...
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Thanks Iowan.
Cool
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Good haul!!
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Good haul!!
Yeah, got most of everything, I needed...
So the install went smoothe with the fan, sway and strut bars, up until attempting the breaks again, got em all together on the one side, but the adjuster spring... Mista spent an hour on it but it got dark on me so I threw in the towel... Think it's oneof those things with a clear mind, it will be easier...
Strut tower brace and sway bar in...
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
The fan...
Cracked and missing...
New and improoved...
The new adjusters so I will have to partially take apart the drums on both sides to put these ones in, plus some lug nuts, and other hardware...
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
So I went out and in about 40 minutes got the driver rear break together with new pick n pull adjuster.
All seemed good, so I thought, why not just drive with one side old bolt, and one new, and see about seating the new breaks on a quick trip around the block.
Well I went around a corner and heard a clanking sound as I hadnt tightened all the wheel lugs enough so limped back home and did that. I took it around the corner again, this time faster and she felt tighter in the turns, and while the brakes worked, they seemed almost no peddle pressure, so I went around once, and came home, and saw driver rear wheel was wet on inside near drums and figured wheel cylinder went out with all the monkeying around on the brake job, so now it is likely really nasty in there, and needing a re do, plus bleed.
5steps forward 3steps back...
I just wish I could confirm just a cylinder seal leaking vs new pick n pull piece being slightly different enough to contribute to it or causing it as other side was working counterpart to bent bolt style. At least next time, I can use all new springs and will be faster..
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Ready for jumps yet?lol
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Yesterday I was ready for yhe tracker to jump off a cliff and me to jump out the door somewhere beforehand.
But im too stubborn to give in... So I woke up early and got the wheels off and rear jacked up...
For comparison after installed yesterday before quick jaunt....
After gunked up...
Other side, figure going to go through both again with new springs this time...
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
So heres the backs of the wheel cylinder...
went to O'Reilly and got two wheel cylinders. Gotta work tonight,
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Went out for a couple more hours...
Made a mess...
Put the new wheel cylinder in, but brakes felt more oval than round when putting the drum on, like outta whack but all there... Used old springs because new springs were waaayyy to tight to get on....
Tried bleeding the rear myself and while pedal pressure improoved, the brake barely turns...
I also like a fool left the other sides drum off while pumping breaks so good thing I bought two cylinders because ill do that side sime other day... Then will try bleeding again...
Added fluid to master cylinder...
I feel like im going to be great at doing brake jobs by the time this is all said n done
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Made a mess...
Repetition yields positive results for future projects
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
See the gold piece below...
See the chrime pick n pull piece in and notice broken wheel cylinder and why I replaced pass side wheel cylinder at same time
See then bend
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Wd40 10mm flare
New wheel cylinder in
All springs in
The scratches tell the tales of attempts
87R10_Cruising
