Project Mini me
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Before....
After....
Before...
After....
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
So when is it’s first off road excursion?
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
I still wanna get some under armor of skidplate and sliders, and rear bumper first...but $$$, and holidays coming...
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Picked these up today...luckily all in stock... I considered ebc drilled and slotted with hawk performance pads but $280 vs 150 plus I got new shoes as my rear rotors were reusable...
Gonna go to recyclers for sway bar I threw out :whymewhyme: for $50 to make it better through turns as she wallows without... I had always heard it gibes you more flex, but I really am slowing to turn, and womder about panic lane change on freeway, so figure it may be best with it on...
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Running 32s vs 27s stock and wanna make sure breaks are solid, and overall more street/ trail worthy
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Going to be interesting to see handling difference as the sway and strut are removed now
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Put it on a quick disconnect system.
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
I looked up quick disconnects for jeeps but different for ifs set up than solid axle so dont know if there is a set up for it or not....plus I uave to move endlinks due to lift per install instructions, so likley will have to revisit it.
But I got the front brakes in... While toyota serviced my prius...
Then I was going to back her in for drum service, but had hard lock up...think it was how I trimmed caliper on other side, and was wondering why I wouldnt have to do this side, but after this, I may, because I think wheel spoke is hitting the caliper and not allowing rotation... We will see but I got work tommorrow, and its late so im calling it...
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Just make your own quick disconnect
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
So this is what made the loud grinding sound/ lock up...
On the caliper....
Painted the wheel and plan to geind to see if it rubs again...
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Spent a long loud day grinding but got calipers done no grinding....
Now just gotta do gears and put sway/strut back on.
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Not gears, rears meaning drums
Mackadocious916
Sacramento
Steve
82 c10, 85 k20
GM
Diesel to gas swap
Went out and jacked up the rear, put jackstands under, and removed wheels...had to go to O'Reilly to get two 8mm x 1.25 bolts to back out the rotor. Since I was one of the first 25, I got a hat for black friday buying 1.70 bolts...
Drum removed...
The left show was bowed out like spring saggy... We will see...break time...
I think I will try and re use drums and just put new shoes in and return mew drums.
87R10_Cruising
