Oilpressure line (copper) connect to engine
FRANK
Chemnitz
Frank
Gmc Sierra
Hi.
I bought a 1977 GMC C15 with 350/350. My Oil Pressure Gauge (mechanical) doesn't work, because it is not connected to the engine.
There are a oil pressure sending unit (one cable) in oil pressure port near distributer.
The unconnected copper line from oil pressure gauge is hanging out the firewall.
I need a picture / photo how is the copper line correct and original connect to engine.
Hope you understand me.
Best regards from germany.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
donnieray
Talks to dogs and trucks.
Roanoke Rapids NC
Donnie
86 C10, 84 K10 MM7 NP833 option truck, 85 K10.
350,355;350.
Welcome. The copper line is after market and most people remove the sending unit and use a 1/8" npt fitting for the copper. 1/8" pipe thread on one side, 1/8"compression for the copper line side. You can rig them both to work.
'73-'77 have mechanical oil pressure gauges with a copper line.
The factory line screws into the block, at the location close to the distributor. I seem to remember the factory fitting style being different than the usual aftermarket setup, but I can't remember what exactly was different about it.
73c20jim
Tombstone, AZ
I'll try to get a picture.
I have the factory line and gauge on my '75, and you can see it in the attached picture. The metal line comes through the firewall rubber plug, and then there is a small brass fitting that is screwed together. The fitting is visible in the center of the picture. From there the hard line is protected by a rubber sleeve, and is then routed down to the block and screwed in. I think the line may be made of steel, not copper, since it does not bend easily.
The line has a threaded fitting that just screws directly into the hole in the block where your sending unit is now installed. There is a notch in the back of the intake manifold to allow space for the screw in fitting.
donnieray
Roanoke Rapids NC
Donnie
350,355;350.
I never knew that. I've only dealt with mid eighties trucks.
hoagster
California
K10, 1500
5.3l
Here's the locaton on the engine
hoagster
California
K10, 1500
5.3l
Do you need them, I have all the connections as you can see in the second picture, the top line (not curly one) is the line that goes thru the firewall. Let me know, cost you some postage!
scawdrey
