oil pump fail
74propu
florida
austin
c10s/b c10 s/b c10l/b
5.3 / ?/454 tbi
yesterday I started my 454 and it lost all oil presser after start shut down and pulled valve cover had oil every where pulled oil sender had oil running out of block . so did the oil pump just stop working all at once?? ordered a new oil pump and pickup (hi volume) I will drop the pan tomorrow and change the pump out and see what it dose . hine sight should have changed the pump out when it was on the eng stand :Insane:
74 Shortbed
Pickup may have fallen off.
Georgeb
Wisconsin
George
K10 Burb Z71
Electric or mechanical guage?
87scotty
Central il
Andrew
V20
5.7 for now
Did you tack the pickup they are known for falling off the 454s
CSFJ
Do the big blocks use the same style plastic collar on top of the oil pump drive that the small blocks use? I seem to recall someone making a steel replacement for them, as it wasn't unheard of for them to get brittle with age.
74 Shortbed
Yes they use the same from the factory, and they do end up in the pan, you find out when you pull the distributor and you hear that horrible thud when the drive hits the bottom of the pan, lol..
74 Shortbed
Tacks are known to break too, I always safety wire the pickup never lose one that way.
Camar068
10 yrs Air Force
MikeB
North Texas
I like the Melling "Select" pumps with bolt-on pickups.
74propu
florida
austin
5.3 / ?/454 tbi
day I pulled the pan and pulled the oil pump out tested it on the bench and pumps the hell out of oil in a bucket pickup is still on the pump put in a new pump and pickup put it all togather and still no presser at the gauge pulled the filter and it pumps out the filter put a bypass hose on it is a gen 6 454 oil cooler lines to the oilpan rail just in front of the filter I am lost now
87scotty
Central il
Andrew
V20
5.7 for now
So bad gauge
74propu
florida
austin
5.3 / ?/454 tbi
I have 2 gauges 1 electric 1 mechanical if I take them out I don't get any presser out of the hole in the block
Georgeb
Wisconsin
George
K10 Burb Z71
Weird!
BugRedC10
