Oil Pan Issues
Kasey 1977 K10
Kasey
I had a small leak/seepage from my oil pan. I picked up a felpro one piece gasket, pulled the oil pan, removed the old gasket and put on the felpro with a bit of seal on the corners and tightened it down. Now I have a much, much worse leak. Any ideas?
350 Small Block - Drivers side dipstick
MikeB
North Texas
Where is the leak?
Kasey 1977 K10
Kasey
Its so wet its difficult to tell. Appears to be at the front and maybe back. The sides look ok. I may get a new oil pan and new gasket and start over.
74 Shortbed
Small blocks had thick and thin front end pieces depend on timing cover, if you require a thick and used a thin you will have a major leak...
CSFJ
Exactly what I was going to say.
Kasey 1977 K10
Kasey
I did put the 10T on the first time but I'm back in business. Not sure if I overtightend the first time or if the old pan was warped. But I put in a new pan with a new gasket with just a dab of ultra black in the four corners and now leek free!
CSFJ
Good to hear.
74 Shortbed
Glad to hear it's fixed..
Ta1nt3d
